Old 11-28-2015, 07:40 PM   #1
Koots
Koots is on a distinguished road
1.6 Roller Rocker Swap
I had a set of 16 1.6 full roller stainless steel rocker arms (Skip White brand) for my old 2.2L OHV turbo Corsica project, but it had to be scrapped before I could completely finish it. So I want to stick these in my 3400 and was wondering if anyone knew what kind of conversion studs I would need for a 99 LA1 and 3/8 stud rockers?
I have a set of ARP rocker studs for the project already (4.3L Vortec studs I believe) and was wondering if they would work (M10 X 1.5 base, 3/8" X 24 top)?
I'm pretty new to modding/learning much about these V6's outside of just regular maintenance. So I got to make sure I have it all right before I start thinking of changing anything. I'm also not concerned about clearance as these are very narrow because they are stainless steel full roller rockers and don't need all that extra material like aluminum versions do. So I hope this will work out for me with zero extra expense.
1999 Alero GL Sedan - 3400/4T45E
-HP Tuners custom tune in the works
-Hopefully much more in the works besides maintenance.
Koots is offline   Reply With Quote
Old 11-29-2015, 10:03 PM   #2
3500Alero
3500Alero is on a distinguished road
IIRC you will need some Gen II push rod guides as well
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
3500Alero is offline   Reply With Quote
Old 11-30-2015, 12:40 PM   #3
Koots
Thank you for the info, I will track some of those down ASAP. Might be a while before these rockers get thrown in (spring probably) but I'd like to have all the parts ready.
