Old 12-23-2015, 01:20 AM   #1
Valley olds
Valley olds's Avatar
Smooth Shifting
I am experiencing smooth shifting... A little too smooth Anyways, lately I have noticed my shifting is very soft. I do not even feel the shifts. The rpms just drop when the car shifts, but there is no apparent bump. Does this mean my transmission is dying? Would a shift kit solve this issue? or will it make things worse?
Old 12-27-2015, 03:15 AM   #2
Koots
Koots is on a distinguished road
Sounds like you either have low fluid levels, old worn out fluid, gummed up internals or a combo of any of them.
I would first check the fluid level and if it's low, just add some more to see if it helps. If it doesn't do much, I would drop the pan, replace the filter and refill with as much new fluid as you can. This will eliminate all the regular maintenance items out of your diagnostic equation.
1999 Alero GL Sedan - 3400/4T45E
-HP Tuners custom tune in the works
-Hopefully much more in the works besides maintenance.
Koots is offline   Reply With Quote
Old 12-27-2015, 02:37 PM   #3
Valley olds
Cool. After reading the "no reverse" thread, I was kind of leaning towards that. Looks like a transmission fluid change is next on my list. After doing the fluid change, I will post if that fixed the issue. Thank you
