Old 09-28-2004, 06:37 PM   #1
anikin8421
Hi guys change the temp gages and still no go rear defrost lights up not werking .
Anyone had this be for????. Also thanks for the heads up on the fan motor reststor I only have the last two speeds as well.
Old 09-28-2004, 06:45 PM   #2
ptrudel
Designated Drunk
mine don't work either...i dunno what it is tho...im pretty sure my switch is dead tho
off topic a lil, wheres aylmer?
I'm baaaackk
Old 09-28-2004, 07:36 PM   #3
anikin8421
in Quebec Anyone eles know about this problem
Dude what do you do in the Winter to clear the back window
Old 09-28-2004, 08:28 PM   #4
bdyman
did ya check all fuses?? relay`s??
sometimes if the lines are scratched it won`t work
Old 09-28-2004, 08:35 PM   #5
ptrudel
Designated Drunk
ah, now i get the PM... ...all i do is scratch it like the windshield...and keep the heat up...which i do anyways in -40degree weather...
I'm baaaackk
Old 09-29-2004, 08:36 AM   #6
Are the plugs in the grid? If not they will have to be sodered back in
Old 09-29-2004, 08:40 AM   #7
3.4 Euro Alero
3.4 Euro Alero is an unknown quantity at this point
Not the first thing I would check, but I was online with Haynes at my garage and there is a regulator box(I can't remember the proper name) in I believe the right rear pillar. This unit controls the rear defroster and has the antenae wiring going through it as well. I believe your stereo reception would not be up to par if their is in fact an issue with it, but with so much power going through it, my tech has replaced a half a dozen of them in the past year 'cause they melt. Really stupid design! Something else to check out.
<span style=\'font-size:12pt;line-height:100%\'><span style=\'color:blue\'><span style=\'font-family:Arial\'>Welcome to the Jungle!</span></span></span>
3.4 Euro Alero is offline   Reply With Quote
Old 09-29-2004, 09:20 AM   #8
misslindseysue
^Yeah. It's on the passenger side C pillar. Antenna booster and defroster are in the same little module. The part at the dealer is $103.
Old 09-29-2004, 09:52 AM   #9
3.4 Euro Alero
Thanks. I couldn't quite remember what side as I read the info last winter and haven't had to replace one yet.
Old 09-29-2004, 01:38 PM   #10
ptrudel
Designated Drunk
i've lived without a radio for the last year and a half...if its that stupid little module, i'll live without a defroster too...i ain't payin that much just so i can "see" out of my window <_<
I'm baaaackk
Old 09-29-2004, 02:58 PM   #11
misslindseysue
Yeah, I didn't buy it either. We went to the parts counter and asked and said "Ok, thanks, bye."
Old 09-30-2004, 09:40 AM   #12
3.4 Euro Alero
Yeah, seeing out of your vehicle is a little overrated!
Old 11-07-2004, 01:08 PM   #13
dbailey
dbailey is an unknown quantity at this point
My rear defroster stopped working but the radio is fine. Not sure how to check the rely under the hood to see if that is what went bad. Any ideas?
dbailey is offline   Reply With Quote
Old 11-07-2004, 01:12 PM   #14
misslindseysue
Look in your owner's manual to find out which relay it is. Then get a friend to help you out. Have them push the button on and off, and listen to see if you can hear the relay clicking on.
Mine stopped working last winter, and I just had to wiggle the plugs at that module in the C pillar. Make sure the grid is plugged in on the back window, too.
Old 11-07-2004, 01:17 PM   #15
dbailey
Ah ha. I pulled the relay out of the box under the hood and plugged it back in. Do you have to take the trim piece off of the rear pillar to access the part you are talking aobut? Thanks.
Old 11-07-2004, 02:13 PM   #16
dbailey
:thumbsup: Checked the relay and its clickin. The fuse in the same box is also good. Now what???? The do hicky in the rear pillar? Thanks.
Old 11-07-2004, 03:24 PM   #17
misslindseysue
Yup, if you made sure the grid was plugged in still. I don't remember what all you have to take off to get to it. It's a lot of carefull pulling. Just have a look at it and start pulling off the plastic that seems to be in your way.
Old 11-10-2004, 04:12 PM   #18
dbailey
Anybody else having the rear defroster not working problem? How do you pull the plastic cover off of the rear pillar without breaking it? I guess that's all that's left to check since everything else seems to be OK. Thanks.
Old 11-10-2004, 04:25 PM   #19
misslindseysue
Very carefully.
Old 11-11-2004, 11:14 AM   #20
coredump
I've had it happen, but my car was under warranty so I just took it to GM told them it was busted and when I went back a few hours later it was working again. Almost like magic or something.
