Old 09-03-2016, 08:58 PM   #1
Babyblue
Babyblue's Avatar
Babyblue is on a distinguished road
Clutch pedal issue
Alright guys...having bit of a problem. Can anyone tell me why my clutch pedal will have a hard time going down? It rarely happens, but when it does I can hear the return spring having trouble compressing? So maybe the spring is worren out? Some more info...clutch does have a leak at the firewall from the master cylinder(buying the new master asap) I keep the clutch rez filled so I don't cause any damage to anything else.Trans fluid is all good. Gears shift fine, no grinding or slipping. Anything at this point will help. Thanks alero community!
Babyblue is offline   Reply With Quote
Old 09-04-2016, 09:07 PM   #2
Bahlzeron
Bahlzeron's Avatar
Bahlzeron is on a distinguished road
I would guess that it's the faulty master cylinder causing it, rather than the return spring. Could also be the slave cylinder, or the clutch. But my money would be on the master being the culprit. To help eliminate variables, put a small amount of light oil (air tool oil, gun oil, 3 in 1, etc) on the spring, and on the pivots of the pedal.
2001 Black GX Coupe 2.4l 5 spd, short shifter, trunk lid w/ spoiler (amazingly from same original dealership), hood struts, Cosmo Evolution SRI, front & rear stb's, GAGT mirrors, more to come
1998 Bravada
I love beer, lots of beers.. I have found dark beers to be my favored.. however Labatt Blue is my go-to.
Bahlzeron is offline   Reply With Quote
Old 09-05-2016, 06:21 AM   #3
The only other thing I could think of as if the pressure plate is binding up.
Old 09-05-2016, 07:03 AM   #4
03Alerosil
03Alerosil's Avatar
The leak could be sucking air into the system. Air doesn't compress. Could be your issue
