Old 09-30-2004, 11:13 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
I think I found good mounting points on the sides but where are descent mounting points on front and back? and are 48" tubes long enough for the sides? or would 2 32"s on the sides and 32" front and back be better? what have you guy's done?
Old 09-30-2004, 11:36 PM   #2
bigd6983
there 48's on the side are fine, i think 2 32's on the sides would be a lil 2 much......if you look on the bottom of the bumper theres a lil gap it fits nicely inside, isnt visible, and gives a great shine.........on the back the frame is up there and it fits perfectly right there.........
Old 10-01-2004, 01:28 AM   #3
1WhiteOSV
here's a few pics that should help with the front and rear neon install...
Old 10-01-2004, 01:29 AM   #4
1WhiteOSV
another
Old 10-01-2004, 01:29 AM   #5
1WhiteOSV
another....
Old 10-01-2004, 01:30 AM   #6
1WhiteOSV
now the front..disregard any hanging wires or messed up mesh grill....lol...mesh isnt there anymore and I've fixed all loose wires
Old 10-01-2004, 01:32 AM   #7
1WhiteOSV
oh yeah.....i DID have it installed on the back of my air dam but i ripped the air dam off in the winter doing donuts in the snow hehehe ...so this is my alternative spot..only downside is that it is visible from the very front at long distances away...mounted on the back of the airdam worked the best because glow still shined out bout the bulb was COMPLETELY hidden :thumbsup:
Old 10-01-2004, 01:35 AM   #8
1WhiteOSV
P.S. YES, those are zip-ties...in the 3 years now I've been installing underbody kits on friends cars and misc. people's cars (over 30 i bet) I've found that zip-ties actually work better than the nylon clips they give you to use with the kit...you can just drill a hole through anything and run a zip tie through it...it's great!..I've had mine zip-tied on for 2 years now and not a single one has ever broken! (in case you're skeptical)
Old 10-02-2004, 12:26 PM   #9
bigd6983
yea zip ties work great, never any problems.......
and yea whiteosv thats where i have mine mounted except for the front, i had it in the old position you did........its completely hidden and it gives a great shine........
Old 10-02-2004, 12:35 PM   #10
ptrudel
Designated Drunk
the only prob is if you do ANY dirt roads, the back one gets bashed quick
as for zip ties, they don't like rocks either <_<
I'm baaaackk
Old 10-05-2004, 10:34 PM   #11
jabartram
AutoCross Alero
jabartram's Avatar
Can you give me some side mount shots, just to be sure where i'm considering is correct? and did anybody have to extent the tube cables? I got the pattern led neons and the cables will have to be extended!
Old 10-05-2004, 10:43 PM   #12
Oldsmopimp
^^^ no dood, theres a way. I have the streetglow neo-blue LED kit, and they all fit. You must mount them as in the instructions....one toob wire does come in with only a lil slack, but it's all in how u wire them. I'll hafta look under there and give u the routes I took, should help ya.
As for the side toobs, mount them behind the pinch weld seam u see. That will hide the toobs from being seen.
Old 10-05-2004, 11:55 PM   #13
1WhiteOSV
I will take pics of mine....I actually used a piece of aluminum cornering...idk what it's called..it's like 1" by 1" and its an "L" shape..kinda like something you'd put on the corner of a wall to protect it..idk...i'll take pics..but anyway I took a piece of that and drilled it up on the sides and mounted bulbs behind it because even behind that pinch weld..the bulb still stuck out about 1/4 inch...I'll take pics..much easier to see/explain.
