Old 11-06-2017, 11:39 AM   #1
Alerodriver17
Alerodriver17 is on a distinguished road
Pinout of the ABS Connector?
Does anyone have the pinout for the ABS pump Connector? I just replaced the transmission in my Alero, and in the process, the ABS speed sensor harnesses got ripped in two but we soldered them back together and it worked for a while. But now the light is on from the moment the car is started and it used to only come on while turn the wheel while the car was in motion. With winter here soon and the first snow not far away. It would be very nice to have ABS and traction control. So my assumption is that the speed sensor harnesses lead directly to the pump, so I’m going to get new hubs and harnesses and run the harnesses directly to the ABS pump because I DO NOT want to pull a lot of the engine bay harness back to replace the speed sensor harnesses. So if I can do it this way that would be SO MUCH easier. So does anyone have the pinout for the ABS pump Connector so I can get this done?
Thanks!
Alerodriver17 is offline   Reply With Quote
Old 11-30-2017, 02:54 PM   #2
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
are you referring to the EBCM? Electronic Brake Control Module? What kind of vehicle do you have? I assume it's an Alero, but what year, trim level, etc
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
Old 12-09-2017, 09:41 AM   #3
Alerodriver17
Whichever module that the ABS wheel speed harnesses run to. I have a 1999 Alero GLS Coupe with the 3400.
