You prolly blew a fuse. Check the left side fuse panel. if all the fuses are still good. then goto the right side fuse panel and check the CRUISE fuse. its a 10amp. When I pulled out my cruise control.. I pulled the fuse out and its tied into the gauge cluster too. So check those fuses. If still don't work.. post back.
if you put in a new fuse and it blow again, then you hooked up the indy glow gauges wires wrong. Unplug it and change out the fuse and see if it blows again.. if not then you wired it backwards.
