Old 10-10-2004, 06:09 PM   #1
Pacho
I was looking at this amp at Crutchfield and the specifications page says this amp produces 2000 watts RMS x 1 at 1 ohm. But at the bottom of the page, it says this amplifier has a 250 amp fuse rating. If the fuse rating was 250 amps, wouldn't the power rating be 2,500 watts RMS because the rockford fosgate 30001 amp which produces 3000 watts RMS has a fuse rating of 300 amps?
[URL=http://www.crutchfield.com/S-p762R7CAzgv/cgi-bin/ProdView.asp?s=0&c=3&g=130&I=575T2001BD&o=p&a=0&cc =01&avf=N&search=amplifiers
Thanks for all comments.
Old 10-10-2004, 07:13 PM   #2
bigd6983
i know its weird but thats the rating they have posted.....if you look at the rms watts at 4 ohms the other amp is only 250 watts more........but at 1 ohm its a 1,000 more.......its just how its set up..........
Old 10-10-2004, 07:39 PM   #3
z3pr
Check out these amps. I currently run a MMATS D200hc, great amp. I want the SSXD1500.1
750Wx1 RMS @ 4 Ohms
1500Wx1 RMS @ 2 Ohms
Old 10-10-2004, 09:05 PM   #4
bigd6983
what are the prices on those amps.......would be perfect to run two dual coiled subs........
Old 10-10-2004, 09:35 PM   #5
Pacho
For the best amp Treo makes is around 1,500 dollars at screaming squirrels audio in s.c. (you can't get treo products on the internet)
Old 10-10-2004, 10:25 PM   #6
z3pr
Best place to get Treo products would be from Metro Audio Dynamic's The same guy that owns that store also owns the company that makes TREO's. Click me.
