Old 10-11-2004, 10:44 PM   #1
GainesvilleAlero
HAS THIS HAPPENED TO ANYONE?
Old 10-11-2004, 10:45 PM   #2
FormulaNERD
cheap belts can squeel... what kind did you put on? you need a poly cog or gatorback for the best results
Old 10-11-2004, 10:47 PM   #3
GainesvilleAlero
ac delco belt.
do they suck?
Old 10-11-2004, 10:50 PM   #4
blueyezalero
I had my serpertine belt changed in another vehicle I owned and it started to squeak also. They told me I could live with the squeal or use some belt spray, I forgot what the actual name of the spray is. Anyways it turned out to be the tensioner...don't know if I spelled that right.
Old 10-11-2004, 10:53 PM   #5
GainesvilleAlero
that was actually the second belt i bought.
the first one squeeled(it was a cheepo)
so i bought the ac delco.
Old 10-11-2004, 11:16 PM   #6
mobs241
your tensioner is bad its holdingthe belt to tight.
tensioners arent that expensive. maby 30 bucks and easy to change. one bolt.. remeber how you loosened the tensioner to release the belt? well loosen that all the way and its off, bolt new one.
Old 10-11-2004, 11:52 PM   #7
King Asoka
King Asoka's Avatar
i have this probelm too. I had a gator back on it and then i put a acdelco and both squeak. But after the car warms a bit the squeak goes away. Is this still a shotty tensioner?
Old 10-12-2004, 12:02 AM   #8
mobs241
sounds like it
Old 10-12-2004, 12:04 AM   #9
FormulaNERD
i didnt loosen the tensioner to put my belt on, i released the pressure using a ratchet at the pivot point like you're supposed to :thumbsup:
Old 10-12-2004, 12:52 AM   #10
mobs241
piviot point? haynes sais loosen tensioner. thats what i did.never heard of a piviot point.
Old 10-12-2004, 01:00 AM   #11
FormulaNERD
yea, opposite of the mounting bolt there is a square hole. you stick a ratchet in there and apply pressure, it takes tension off of the belt.
Old 10-12-2004, 01:07 AM   #12
mobs241
ohhhhhhh just as easy to lossen tensioner
