home depot has fiberglass stuff under their house paint section. For bondo .. STAY AWAY FROM BONDO BRAND. Use Rage GOLD or rage lineup made by evercoat. Its the easiest sanding bodyfiller out there. If u want the cheapest fiberglass products.. goto your local marine/boat supply store.
You will need
-4" plastic spreaders
-36 grit sandpaper
-80 grit sandpaper
-150 greit sandpaper
-220/240 grit sandpaper
-Air grinder with 27,36 or 40 grit sanding disc
-DA sander
-Body filler
-Fiberglass resin/harder and fiberglass mat
Get some paint sticks to mix thing and to get the bodyfiller out the can (free from home depot)
-Get a construction paper booklet for to use as a mixing board for the bodyfiller. Cuz once ya done with it mixing and spread.. just tear the page away and your off to a clean new sheet. While they do sell mixing board, but then u need to clean it everytime you use it after mixing.
I think thats it. Some more stuff u need .. is lots of time and patiences with shaping and sanding
