Old 10-14-2004, 12:58 PM   #1
-Alero-
-Alero-'s Avatar
i have a set of springtech springs sittin in my garage, and all i need to do is install them. im getting price qoute for up to 300$ just to get the springs on and alignment. do i really have to get alignment when i put these springs on? and how much did you guys pay to get your springs put on? i also remembered i could get a spring compressor from autozone, but i'd still need to alignment. someone give me some hints on what to do
AUTOBOT
Old 10-14-2004, 01:01 PM   #2
jackal2000
jackal2000's Avatar
you probably wont need an alignment if the install is done properly, i didnt. i installed them myself so i am not too sure about the quote. that sounds expensive though.
Old 10-14-2004, 01:06 PM   #3
99BLKALERO
that is what they quote up here too.....so i had my buddy do them for some beer.
no alignment needed
Old 10-14-2004, 01:31 PM   #4
b-spot
b-spot is an unknown quantity at this point
Originally posted by jackal2000@Oct 14 2004, 11:01 AM
you probably wont need an alignment if the install is done probably, i didnt. i installed them myself so i am not too sure about the quote. that sounds expensive though.
you mean pimpslayer installed them himself
If I did went to college...
b-spot is offline   Reply With Quote
Old 10-14-2004, 01:46 PM   #5
-Alero-
-Alero-'s Avatar
so i dont need to get alignment!? sweet!
AUTOBOT
Old 10-14-2004, 02:08 PM   #6
99BLKALERO
no you shouldnt, I have had lowering springs on 3 cars now....and no need yet.
Old 10-14-2004, 03:23 PM   #7
1WhiteOSV
High Rev did my springs AND struts for $100....then I got mine aligned (4wheel) for $55...so...that's 1/2 what u were quoted at..
adam
Old 10-14-2004, 07:10 PM   #8
Youngblood77
Youngblood77's Avatar
no alignment needed, eh? Sounds good to me, I got Flashy's springtechs sitting in the origional box in my back room, waiting for installation. Gotta buy an impact gun and rent the spring compressor, then i'm off to the races B)
Old 10-14-2004, 07:43 PM   #9
AGT
AGT's Avatar
You can do em yourself. I did. If you mark where your originals were then you wont need an alignment but watch out if you forget to mark em. I spring compressor is a good tool to have anyway. Keep it in mind that if you dont have an air compressor than take it somewhere to get it done because the strut nut takes some pressure to get loose. :thumbsup:
Have a good day
Old 10-14-2004, 07:45 PM   #10
jackal2000
jackal2000's Avatar
Originally posted by b-spot+Oct 14 2004, 01:31 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (b-spot @ Oct 14 2004, 01:31 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-jackal2000@Oct 14 2004, 11:01 AM
you mean pimpslayer installed them himself [/b][/quote]
if thats what you want to believe :rolleyes:
you missed the point of my post anyways which was that it can be a DIY job without an alignment
Old 10-14-2004, 08:57 PM   #11
-Alero-
-Alero-'s Avatar
yeah i know i could do it myself, all i gotta do is rent the spring compressor, cause i got an impact wrench and i got more tools then i need, problem is im gonna need to know how to "mark" where to put these, and i might need a walk through so i dont f*** anything up.
AUTOBOT
Old 10-14-2004, 09:31 PM   #12
FormulaNERD
dude, there is a "tab" on the plate that the springs rest on, it's hard to explain, but you put the spring against it, like the stock one. its cake.
Old 10-14-2004, 09:44 PM   #13
jackal2000
jackal2000's Avatar
exactly, the pic isnt the best but what formula was talking about is circled in red. the bottom of the spring rests up against it.....
Old 10-14-2004, 09:49 PM   #14
FormulaNERD
yep, that's it. and the top plate only goes in one way, just make sure that lines up with the lower mount the same way it did when you took it off... the top plate has a flat side if i remember right, and you can use it as a reference point.
there is a how-to on here, and i used that... no problems whatsoever.
Old 10-14-2004, 10:02 PM   #15
-Alero-
-Alero-'s Avatar
yeah i found that how-to. doesnt seem like the hardest job, just kinda seems time consuming. i guess i'll try to get started on monday, where i have some daylight. just hope it doesnt rain <_< . but yeah all i needed to know if it needed alignment, and seeing as how it doesnt i'll be fine. thanks guys
AUTOBOT
Old 10-14-2004, 10:10 PM   #16
FormulaNERD
yea, i think it took me about 3 hours... and that was the first major mod i did myself
