Old 10-22-2004, 04:34 AM   #1
Spilner521
Boost Guru
Spilner521's Avatar
I'm getting ready to start my turbo project for my 2.4l. what i'm asking is if anyone knows how much the stock internals of this engine can take. i'm not using a pre-assembled kit, i'm doing all custom work and i wont be using a huge turbo - probably a t3 at the most. i'll be using the neccessary fuel adders - bigger injectors, fuel pressure regulator, maybe a new fuel pump, and engine management - so i'm just wondering how much i can turn up the wick without sending a piston through the bottom of the block.
Old 10-22-2004, 09:19 AM   #2
Not too sure about the 2.4 but I heard the 3.4 can handle about 8 to 10 lbs of boost, but 10 is the max.
Where are getting the PCM from?
Old 10-22-2004, 04:46 PM   #3
Final-Reality
It should be able to handle anywhere from 8-10 psi as long as it's properly tuned. I say SHOULD because obviously there is no guarantee, and there's always a possiblity you'll spin the #2 or #3 rod bearing, they're almost always the first thing to break under boost.
Old 10-22-2004, 06:17 PM   #4
Oldsman
Owner
Oldsman's Avatar
yep 8-10 psi. i would actually stop at 8.
Beware of the BackStabber
Old 10-22-2004, 07:16 PM   #5
Spilner521
Boost Guru
Spilner521's Avatar
OK...i was planning on running probably 6-7 psi so that'll be fine...at least until i pick up some forged and decompressed pistons. i'm not sure about the fuel controller yet....i 've heard only good things about the apex'i safc so i might go with that.
Old 10-23-2004, 08:11 PM   #6
Final-Reality
The Apexi S-AFC sounds like a good deal, allows a amount of flexibility and tuning ability for the cost..
Old 10-26-2004, 07:39 PM   #7
nguyen187
hey do it!!!! but be warned its a pain in the azz!
most people on here are correct the motor can hold bout 8-10psi pretty good, but do do the necessary upgrades, fuel, oil cooler, etc.
Putting the necesary pieces togther is really not all that bad, if you need help just PM me i'll do what i can.
