Old 10-22-2004, 12:44 PM   #1
tenny
is it possible to swap my auto tranny for a 5 speed? I think the ones out of the cavaliers will work?
a 3400 5 speed would be niiiiiiiice.
Old 10-22-2004, 12:47 PM   #2
FormulaNERD
nope. not a simple swap anyway. with cash ANYTHING can be done.
Old 10-22-2004, 12:51 PM   #3
sc/alero
springs is doing it talk to him he can give you the aprox. cost
Old 10-22-2004, 01:14 PM   #4
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I dont think it can be done. GM doesnt even make a 5 speed for the 3400 not to mention all the extensive modding need to the wiring.
Old 10-22-2004, 08:01 PM   #5
tenny
i'm almost positive a 5 speed out of a 2000 and up cavalier would work
Old 10-22-2004, 08:02 PM   #6
tenny
or what about the ones out of the older cavaliers that came with the 3100, one of those would surely work. Then get the computer reprogrammed.
Old 10-24-2004, 02:47 PM   #7
springs fastest alero
Senior Member
springs fastest alero is an unknown quantity at this point
its been discussed before and I'm doing it now.
dont feel like reposting all the info so here ya go.
http://invision.aleromod.com/index.php?showtopic=5172
I may actually be going 6 speed though. depends on my latest findings.
now sporting 3 pedals
<img src=\'http://invision.aleromod.com/uploads/post-25-1071111759.gif\' border=\'0\' alt=\'user posted image\' />
springs fastest alero is offline   Reply With Quote
Old 10-24-2004, 02:49 PM   #8
Senior Member
the 3100 never had a manual trans
3.1 mpfi did though
Old 10-24-2004, 09:58 PM   #9
tenny
thanks for the link, keep us posted on how your swap is going.
I wont be doing mine for a while cuz i clued in that if I did it now my warranty would be all shot to hell (2004 model year) so i'll have to wait about a year till im over the miles. hopefully by then a few people will have done it.
I am positive that the 2000+ cavalier 5 speed will handle the power of the 3400 though, because a guy swaped a 3.8 SC with NOS into a cavalier with the 5 speed and had no problems at all.
Old 10-26-2004, 10:02 AM   #10
jturkey69
jturkey69's Avatar
jturkey69 is an unknown quantity at this point
Send a message via Yahoo to jturkey69
if i had a chance to do it all over again id go with the ECOTEC w/5spd, and then boosted it....but i didnt find this board till after i got my alero.. <_< ..anyways, overdrive75 will tell you that you will have alot of problems with the computer so it really isnt worth it to try the swap, unless you have alot of money to play with...im sure springsfastestalero will have some nightmares with going into his swap,being the first to do it, but he does have some finances to work with.
OCA Alero Chapter Member!!!!
ALERO-LESS
jturkey69 is offline   Reply With Quote
Old 10-26-2004, 10:27 AM   #11
MikeSS
MikeSS is an unknown quantity at this point
Yeah, that is exactly why I went with my car. I didn't even realize the potential of this motor when I first bought it, but really lucked out.
2010 WRX 265 - AWD Boost
2004 RX-8 GT - Gone
2006 Cobalt SS 2.4L VVT - 15.05 @ 94.91 - Gone
1996 Camaro Y87 - Gone
2003 Alero 2.2L GX 5-Spd - 15.21 @ 88.21 - Gone
MikeSS is offline   Reply With Quote
Old 10-26-2004, 12:19 PM   #12
tenny
what's so great about the ecotec? you cant do anything with it that you cant do with any other engine.
Old 10-27-2004, 12:47 AM   #13
Senior Member
its not costing me as much as you would think
the killer part is making it handle my projected power.
mastercard is covering this project
but you must keep in mind I've been seriously digging into the project for over a year now.
I have time since my motor is still in the machine shop and waiting on parts.
also being the motor is not in the car makes it easier to work with things in getting all the components for the manual installed
Old 10-27-2004, 12:59 AM   #14
Final-Reality
Gees springs you still havnt decided on the transmission you want? Get crackin' :P
Have you found out any more info on said 6-speed transaxle yet? The G6 GTP has an optional 6-speed I know that, but is it the same Getrag that's been used in the Saab 9-3 Aero's?
Old 10-27-2004, 01:10 AM   #15
Senior Member
I have the trans here
94 cavalier Z24
thoughts I'm toying with are: close ratio gears, 3.94 final drive ratio, sixth gear kit, limited slip differential.
the limited slip is pretty much a must with my setup
I also want the close ratio gears.
my co-worker says he has info on a place that sells a sixth gear kit for the getreg 282.
5th is on its own shaft and there is room for another gear.
guess its been done
I'm still trying to find more info.
the manual project is actually what I currently have the most parts for
I'm waiting on many things for the engine and also many things for the supercharger
Old 10-27-2004, 01:12 AM   #16
Final-Reality
I see... well take some pictures, always makes for a good post
Old 10-27-2004, 09:14 AM   #17
jturkey69
jturkey69's Avatar
well with the ECO you can boost it up to 400 horse before rod issues MIGHT come up, stock fuel system is good enuff for 260 whp, then it gives up....some have said with swapping the rods(i believe in the j-body feature in HCI magazine), and fuel an new intake system ....on boost will net around 550 to 600....i dont think ive seen a 3400 do that, theres not the aftermarket like the ECOTEC has
ALERO-LESS
Old 10-27-2004, 09:45 AM   #18
MikeSS
Originally posted by jturkey69+Oct 27 2004, 08:14 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (jturkey69 @ Oct 27 2004, 08:14 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-tenny@Oct 26 2004, 04:19 PM
well with the ECO you can boost it up to 400 horse before rod issues MIGHT come up, stock fuel system is good enuff for 260 whp, then it gives up....some have said with swapping the rods(i believe in the j-body feature in HCI magazine), and fuel an new intake system ....on boost will net around 550 to 600....i dont think ive seen a 3400 do that, theres not the aftermarket like the ECOTEC has [/b][/quote]
With stock internals and nothing more then boost, the eco will run up to 283hp before it gives up the ghost.....A few internal mods and they had it running at 350HP without problems.....if I had a lot of cash i would do this......but being the broke man I am
And S/C....I can't wait to see what kind of times you can get with a 6-speed tranny
2004 RX-8 GT - Gone
Old 10-27-2004, 09:55 AM   #19
ptrudel
Designated Drunk
i wishi had the eco too....but then again, i wish i had money...
i can't wait to see springs with the manual too :thumbsup:
I'm baaaackk
Old 10-27-2004, 10:16 AM   #20
tenny
i'd still rather have the 3400 then the ecotec.
