Old 12-08-2003, 09:47 PM   #1
David
Hey everyone. This is my first post so let me introduce myself. My name is David from Toronto. This is a cool community you have here. I'm glad I found a place to talk Alero's.
Anyway, I'm having some problems with my car. I was wondering if any of you guys have had the same problems, maybe you can let me know how you fixed them. I did do a search but there were some things I couldn't find.
My car is 2000 GL with the 3.4 litre V6 and 70,000km on the clock. The car is totally stock. Oil is changed every 5000km. Car is fully maintained by my dealer.
Anyway, here's my list.
1. Car makes a squealing noise coming from the front passenger side wheel whenever the car is moving. It seems to get faster and louder the faster the car goes.
- Could this be the wheel bearing problem I read about in my search?
2. Car makes a groaning/whining and whirring (think of rubbing two pieces of polyster together) noise whenever I turn my steering wheel.
- I'm thinking power steering pump, but not sure.
3. Whenever I drive it sounds as though I have a bag of marbles rattling around in my dash above the radio.
- Have no idea what is causing this
4. Whenever I drive on the highway at or above 120km/h the steering wheel vibrates excessively.
- Dealer balanced the wheels at my last oil change but it didn't help. It is obviously something else but I can't figure it out.
5. The "Charging System Indicator Lamp" in the dash comes on every morning when I start the car. It goes away whenever I put the car into drive. A couple of times It has come on while driving, but goes away after a couple of seconds.
- When my dealer looked at the car they said they couldn't find any electrical faults anywhere. They did some test apparently. So I'm kind of scratching my head as to what is tripping off the light.
Thanks in advance for any insight you guys can provide.
David.
Old 12-08-2003, 10:59 PM   #2
freeze12
The squealing sound You hear probably is worn brake pads as on the inboard pad there is a piece if metal that sticks out & when the pads wear so much the metal piece hits the rotor causing the squeal.
The shaking You have is probably bad front rotors ( a common Alero problem) as GM put on junk for rotors. Also when the car is jacked up rotate the front wheels to be sure that there is not a caliper sticking on You.
...Dan...
Old 12-08-2003, 11:15 PM   #3
99blackalero
i had that squealing sound when i drove and it got faster....it was the bearing, changed it and the sound went away
Old 12-08-2003, 11:16 PM   #4
99blackalero
im havinf this problem, it comes and goes...what can be done to fix this and whats causing it
Old 12-09-2003, 11:24 AM   #5
3.4Alero
1. Probably the bearing. It should not be the brakes. If it were, you SHOULD only hear it when you hit the brakes, unless you have NO pad left.
2. I have something similar, but it sounds as if it's coming from the steering column itself. If yours sounds like it is coming from the engine bay, then it probably is the power steering pump.
3. A screw may have come loose and dropped inside the dash somewhere. Pull the radio assembly out and see if you can pinpoint it.
4. You probably need an alignment.
5. Bad alternator or loose connection to the charging system?
Hope that helps a little. Keep us posted as you figure things out!
Old 12-09-2003, 01:31 PM   #6
David
Thanks to everytone for their responses, I really appreciate it.
I have to take the car to the dealer soon for an oil change so I'll see what thet say. Don't know if I'll metion all these things tom them on this visit. It'll probably cost me an arm and a leg. I'll have to do it bit by bit.
99blackalero,
I wish I knew what the steering sound was. It is really annoying!
3.4Alero,
The "whirring" sound I described in my first post for my steering problem sounds as though it is coming from the steering column itself as well. The whining and groaning sound like they are coming from the engine bay. I should have been more clear in my first post. I'm not sure if they are mutually exclusive things. I just assumed they had some connection.
I'll definately keep everyone posted as I get these things resolved. Thanks again!
Old 12-09-2003, 06:57 PM   #7
Final-Reality
I have the whirring sound too, especially when it's cold, I live in a parking garage so when I drive out I turn it lock to lock a lot, and it's just shaft/mechanism/gears in the steering column, nothing's wrong though, I've gotten used to it, and the whirring sound is now oddly cool to me B)
Old 12-09-2003, 07:07 PM   #8
johny_boy32
johny_boy32's Avatar
also....welcome to the site.
Old 12-11-2003, 11:19 AM   #9
PapaBear101
Add steering wheel fluid to correct #2....
#4 how, are your tires looking?
Old 12-11-2003, 12:07 PM   #10
alerosport.com
welcome,
Does your stering wheel vibrate only when you apply the break? or get worse at higher speeds?
Old 12-11-2003, 06:10 PM   #11
flalero
Warped rotors will not cause your wheel to vibrate unless you are braking. It is most likely you tie rod end. Mine was bad on the left side. The car would vibrate very badly. I balanced my tires and that didn't work. Finally, when I went in for an alignment after I lowered my car, the serviceman said that they need to replace the left tie rod end. Just reach around behind the front wheels where the strut meets the wheel, just aft of the strut is your tie rod end. If it moves at all, it is bad and I can almost guarantee this is causing the vibration.
Old 12-11-2003, 09:40 PM   #12
David
Hey guys. Thanks for all your responses!! Anyway, let me give you an update. I took my car to the dealer today for an oil change and 40 point inspection. I'm also a goof!! More on that later. Here is a rundown of my list with the solution in bold.
During the 40 point they told me I had 0% of pad left on my front brakes. I needed new rotors and pads. The squealing sound seems to be gone. It seems as though Freeze12 was right on in his post.
I never reported this. The brakes alone set me back!
I never reported this either. Next time.
It vibrated while I was driving and while I braked. I know the braking vibration was from bad rotors as I've had the rotor problem once already. The vibration while driving is the one I'm not sure about. flalero's tie rod hypotheseis sounds very likely. The brake job fixed the braking vibration. I haven't had a chance to go above 120 yet. Maybe the other vibration will mysteriously be fixed as well. I know, wishful thinking.
I'm a total idiot. This light used to flash so quickly that I never was able to get a good look at it. It looked like the battery light, but it wasn't. Turns out it's the low coolant indicatior light. For the American ppl on the board, keep in mind, our indicators are pictures and not words like in your cars. So be gentle on me, lol!
This brings me to my next problem. During my 40 point inspection the tech wrote under the "engine or transmission leaks" section that my "intake is leaking". I never saw this until after I left the dealer. WTF is it leaking?? Is it leaking coolant or something? Has anyone heard of this before? How much is it to fix?
That's my summary for now. Thanks again for all your help!
Old 12-11-2003, 09:55 PM   #13
sound_xtreme
sound_xtreme's Avatar
indicator lights are pictures in all aleros
Cardomain
Old 12-11-2003, 09:57 PM   #14
sound_xtreme
dreaded intake manifold leak. costed me 800 USD to fix mine. have fun if that is what it is. it leaks coolant into your oil and sometimes can leak out also. gotta get it fixed soon. coolant in oil is bad for everything.
Cardomain
Old 12-11-2003, 10:45 PM   #15
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
Mine are all words.
For your vibrating while driving my lincoln had the same problem and i also thought that my tie rods where going. I also had the same noise with my steering and it turned out that the resivoir was extremly low. Afterfilling it up it turned out that the vibrating was gone. After talking to my mechanic I found out that with rack and pinion steering when you are low on fluid they vibrate, so to make a long explanation short check your power steering fluid.
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
Old 12-11-2003, 10:55 PM   #16
brsexton
nope, not true here. Mine are all words.. IE "Service Engine Soon" "Washer fluid Low" Ect.
2005 Honda CR-V AWD
Old 12-11-2003, 11:00 PM   #17
sound_xtreme
those are, but coolant, battery arent kids.
Cardomain
Old 12-11-2003, 11:38 PM   #18
Aleromaster
Then it makes the three of us right but its 11 to 5 with the words winning here
Old 12-13-2003, 10:39 PM   #19
Johnnyangel
Hiya, I know this was already answered, but as a service advisor and former alero technician, any time I've ever had a customer with a 'battery light', it's been the coolant light, and subsequently a set of intake gaskets- I can do it in about 2 hours for $48 worth of gaskets, myself- but at the dealer, it can run you up to $600 depending on the labor rate. If you do plan on doing it yourself, it's pretty straightforward, but do yourself a favor if it's your first time and make a large grid on a big piece of paper and label the bolts in each square with where they go so you can put them on in reverse order we you put it all together. Also, do yourself a HUGE favor and change the oil pump o-ring at the same time- it's the round thing on the driver's side underneath the lower intake. You'll need the plastic lower intake gaskets, paper upper intake gaskets, rubber valve cover gaskets, EGR valve gasket, oil pump O-ring, and a tube of grey sealer for where the intake gaskets meet the valve covers and across the block between the heads. (all available at your dealer) Some of the bolts that hold the lower intake on are going to be submerged in coolant when you get to them, so don't get discouraged! MAKE SURE YOU HAVE A 1/4" DRIVE UNIVERSAL JOINT! You will NEED IT!
:thumbsup:
Old 12-14-2003, 12:01 AM   #20
Final-Reality
There's a difference between canadian and american aleros
Canadian ones have to use pictures, because we're bi-lingual, american's dont even have an official language AFAIK, so they just use english words, that acutally make sense, instead of some stupid icon to represent "low washer fluid"
