Old 12-07-2004, 11:11 AM   #1
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Ok last night this little honda was going down my road doing 25 in a 40 So I reved my engine up in Neutral to try to get them to move, well it took about 30 seconds for it to come back down from 5000 rpms to about 2000 rpms then I put it back in gear. What you guys think?
Old 12-07-2004, 12:08 PM   #2
ptrudel
Designated Drunk
just stop doin that and you'll never notice it again
you're engine is never gonna go from 5000rpm back to 2000rpm in 2 seconds
I'm baaaackk
Old 12-07-2004, 01:15 PM   #3
misslindseysue
Ever take physics? An object in motion will tend to stay in motion, unless acted upon by a force. That force would be friction. Since you want to reduce that in an engine, there isn't much. So things keep spinning, which is what "neutral" is. Nothing is engaged. So:
#1: duh.
#2: don't do that.
Old 12-07-2004, 10:57 PM   #4
bigd6983
#1: duh.
#2: don't do that.
yea thats true, but from 5,000 rpm down to 2,000 rpm it doesnt take 30 seconds give or take some im sure, in gear its going to come down slower say in ur 2nd gear and u get up to 5 and let off, it will take a while to get back down to 2........but in neutral, it isnt instantaneous but it should be a lot quicker than that.......check that your throttle cable isnt stick anywhere, get some to push on the cable and check the throttle connection at your throttle body.....
Old 12-07-2004, 11:35 PM   #5
Oldsman
Owner
Oldsman's Avatar
well i know mine does something like this. If driving or coasting and you put it into N and rev it you can hit 6500.
I did that a couple times and when you do this it seems to sit at that rpm and goes down slowy. if this is what you mean then it is normal and don't do it anymore.
Beware of the BackStabber
Old 12-08-2004, 09:16 AM   #6
misslindseysue
Exactly!!
Old 12-08-2004, 09:55 AM   #7
2000NavyAleroGLS
I'm sure what your trying to say is more to do with the throttle cable being a little sticky. Because I know that the Alero has enough compression to slow the revs down a lot quicker than that. It should be around 2 seconds in neutral.
Old 12-08-2004, 09:57 AM   #8
ptrudel
Designated Drunk
from 5000 down to 2000? never...
I'm baaaackk
Old 12-08-2004, 09:58 AM   #9
2000NavyAleroGLS
If you rev it up in nuetral. It should be.
Old 12-08-2004, 10:38 AM   #10
bigd6983
maybe not two seconds but not thirty, especially at the speeds he was going i cant imagine it taking 30 seconds, if that happened to me id be freaking out too......
Old 12-08-2004, 08:07 PM   #11
Oldsman
Owner
Oldsman's Avatar
i wonder if he has heard of WD-40??????? might want to try it if it is really sticky.
does it stick any other time or just when you do that?
