Old 12-12-2003, 01:47 PM   #1
justinusaf
justinusaf is an unknown quantity at this point
Send a message via AIM to justinusaf
When you put bigger wheels on do you necessarily need bigger brakes? I think not but someone said that you do. I dont think they have that much of an effect. Any input is appreciated.
Pheenz Motorsports Founder
justinusaf is offline   Reply With Quote
Old 12-12-2003, 01:57 PM   #2
Pimpalero03
not really, if your just getting 17s or 18s then no. cross drilled rotors would look nice bihind the rim but u dont need bigger rotors or brakes. now if your getting 20s then yes you should get bigger rotors and brakes
Old 12-12-2003, 02:14 PM   #3
misslindseysue
I have 17's for summer, 15's for winter, so I didn't change the brakes. If you want to run 17's or 18's all year, you can put bigger brakes on, but you don't need to. Cross-drilled rotors would look better, and help you out, but aren't absolutely necessary. I'm going to get some as soon as this set of rotors warp, but in the same size as factory. Bigger wheels most likely will add some weight, making braking more difficult, so that is something to consider.
Old 12-12-2003, 02:32 PM   #4
r53silver91s
r53silver91s is an unknown quantity at this point
No u don't, I have 18's and before I got brembo rotors and 911 brake pads I had stock rotors and brakes and they worked just fine.
<a href=\'http://members.cardomain.com/r53silver91s2\' target=\'_blank\'>http://members.cardomain.com/r53silver91s2</a>
<img src=\'http://invision.aleromod.com/uploads/post-24-1088131656.gif\' border=\'0\' alt=\'user posted image\' />
r53silver91s is offline   Reply With Quote
Old 12-12-2003, 03:56 PM   #5
havik
You should be ok, but don't plan on keeping your original size brakes and rotors. Since you're getting bigger wheels, you might as well get bigger brakes though. You'll decrease your stopping distance, and since you'd be changing them you have an excuse to get cross-drilled rotors.
Old 12-12-2003, 06:06 PM   #6
needforspeed
think u can fit 20's on a alero?
Old 12-12-2003, 06:35 PM   #7
sound_xtreme
sound_xtreme's Avatar
yea, gotta do some moving of the suspension but yea. lol
Cardomain
Old 12-13-2003, 01:19 AM   #8
evilinside09
an easy alternative to new rotots, calipers, pads, etc is braided stainless steel brake lines. this is definitely on my to-do list for the spring because the rubber hoses that brake fluid travels through can expand and contract, making braking inconsistent. braided stainless steel lines do not expand. i think pfyc.com has em.
