Old 12-08-2004, 02:48 AM   #1
Xx91stangxX
just wondering if the 3.4 comes with stock forged pistons or hypers. i was wanting to run like a 50-75 dry shot on it...let me know thanks!
Old 12-08-2004, 09:43 AM   #2
If you're going to do it be careful. There has been a lot of blow motor stories on here with spray.
If you're going to do it, I've heard NOS or NX are the best. Wet shot 50 or less
Old 12-08-2004, 09:44 AM   #3
wy3134
wet shot, dont bother w/ dry, thats almost a guarantee to blow the motor, im running wet, its a lot safer. I should be getting my wet kit i bought off here this week, im anxious to run it in a couple summers after i have the engine built up a bit (i feel that i should beef the engine up so the abuse of nitrous isnt as bad on the engine, mainly the rods, pistons, heads, intake and exhaust. with this comes having to get some new camshafts probably, etc....but IMO better safer than sorrier runnin nitrous on complete stock)
Old 12-08-2004, 01:22 PM   #4
-Alero-
-Alero-'s Avatar
do what ever you want for nitrous just make sure you get a better MAF so your engine can burn enough fuel for the nitrous, otherwise you will run too lean and your motor will blow up! so i dont think it really matters what shot you run just as logn as your car delivers enough fuel too burn up all the air.
AUTOBOT
Old 12-08-2004, 01:24 PM   #5
-Alero-
-Alero-'s Avatar
double post sry
AUTOBOT
Old 12-08-2004, 01:59 PM   #6
wy3134
lmao totally forgot about that, im also adding a second fuel cell (a small 3-5gallon, not sure yet) that will solely be for fuel when i hit the nitrous, and ill probably run something around 100-105 when i hit nos so that it burns hot enough and dont get detonation
Old 12-08-2004, 02:45 PM   #7
Xx91stangxX
yeah thats a good idea....see i run nitrous on my stang....but thats a whole different ball game to me i know the stuff....but i have no clue what stock injectors are on here or what size pump comes stock...so its new to me....but i might just steer clear of the nitrous due to the unfamiliarity of the alero motor.....better safe and not use it then use it and blow up a brand new motor
Old 12-08-2004, 03:01 PM   #8
wy3134
what makes it tough is i have the ecotec and its a whole different ballgame for that engine compared to the 3.4, mainly cause the parts available. there are guys on here who have heavy modded 3.4's but idk many if any runnin nitrous, other than maybe springsfastestalero
Old 12-08-2004, 04:02 PM   #9
I got the wet and dry confused, only go wet on this motor.
There is no way to go dry and not keep the motor from running lean
Old 12-08-2004, 04:05 PM   #10
he's not running at all right now... ..........there have been some, sc/alero used too but he blew his motor, now he is only boosted no funny gas for him.....
Old 12-08-2004, 04:59 PM   #11
wy3134
my goal/dream is to run nitrous till i have the turbo setup done, then do away with nitrous unless i can get a special setup that is used for low rpm to negate somewhat the "turbo lag" although its not that major, but if i do this i can almost guarantee ill be goin through motors too fast, which is why ill do away w/ nitrous more than likely after i do get the turbo setup
Old 12-08-2004, 09:46 PM   #12
SilverBullet256
Senior Member
SilverBullet256 is an unknown quantity at this point
Send a message via MSN to SilverBullet256
springs had nitro and boost on his engine for a while, but it finally just crapped out and now he is in the process or rebuilding new engine just for performance :thumbsup:
SilverBullet256 is offline   Reply With Quote
Old 12-08-2004, 09:53 PM   #13
that is a big negative..........he never had boost and nitrous at the same time....
Old 12-08-2004, 09:54 PM   #14
SilverBullet256
Senior Member
i didnt mean at the same time, i meant altogether he has had both, which create alot of pressure on engines, and his lasted for a while, thats what i meant
Old 12-08-2004, 09:56 PM   #15
oh ok..............Xx91stangxX: i think you coud safely run say a 35 wet shot for a long time with very minor fuel modifications.....
Old 12-09-2004, 10:16 AM   #16
isellalerodrop
I run a 50 shot nx kit on my 3.4, they have one thats specific for the gm 3.4 so go with that one if you want one. Just make sure its switched and not running all the time you get on the gas so you can control when you use it and you should be fine. Just run the highest gas and go easy with it.
Old 12-09-2004, 11:04 AM   #17
mike2002
mike2002 is an unknown quantity at this point
Send a message via Yahoo to mike2002
i thought this was your girls car, and you just wanted to put a few go fast bolt ons in, like intake/exhaust/pcm......this one might piss her off....LOL
2001 Alero GLS - Sold!
mike2002 is offline   Reply With Quote
Old 12-10-2004, 02:56 PM   #18
Xx91stangxX
how many girls do you know that pop hoods? mine sure as hell doesnt
Old 12-10-2004, 03:09 PM   #19
Old 12-10-2004, 04:44 PM   #20
wy3134
hey mustang, ive got a nitrous kit if your looking for one (wet). lmk
