Old 12-17-2004, 12:17 AM   #1
jwth2005
Hey all i have a bit of a problem.... My car has had a very bad unresponsive brakes since i have bought it.... Im not sure if its a bad vaccum or what.... I would justn like to have some response in my brakes back. Another thing i have noticed is that when i approach a complete stop i hear a clanking noise... And it only happens WHEN the brakes are applied. it goes away once i lift my foot off the pedal... So pleas anyone HELP!!!!
Old 12-17-2004, 12:56 AM   #2
Oldsman
Owner
Oldsman's Avatar
first off would be check rotors, calipers, bolts for calipers and caliber bracket. check pads. if everything looks good. might have to take it to a shop.
Beware of the BackStabber
Old 12-17-2004, 08:10 AM   #3
3.4 Euro Alero
3.4 Euro Alero is an unknown quantity at this point
Also, do you have rear drums or rotors?
<span style=\'font-size:12pt;line-height:100%\'><span style=\'color:blue\'><span style=\'font-family:Arial\'>Welcome to the Jungle!</span></span></span>
3.4 Euro Alero is offline   Reply With Quote
Old 12-17-2004, 11:08 AM   #4
jwth2005
all 4 are disc
Old 12-17-2004, 04:34 PM   #5
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Now I actaully looked in my haynes manual for this and spungy brakes is the abvious air in lines, or mastercylinder bolts loose or master cylinder gone. The clanking noise I guess could be a loose master cylinder.
Old 12-17-2004, 04:46 PM   #6
I to vote for air in the lines but I also say for the clanking, check calipers bolts
Old 12-17-2004, 08:44 PM   #7
jwth2005
I actually thouight about the possibility of air... im glad im not crazy to think that now... thanks everyone i appreciate your help!!!!
Old 12-17-2004, 10:36 PM   #8
misslindseysue
Very first of all I'd pop the hood and make sure your reservoir is full of brake fluid.
Old 12-18-2004, 04:25 PM   #9
bman_84
I would say check the brake fluid too, my brakes were mushy, fluid was low, put more in, and problem solved. I don't remember if there was a clanking sound or not, since then my front pads have been changed.
Old 12-18-2004, 05:41 PM   #10
AftermathAlero
Bleed the brakes like 5 times all the way around. if still mushy.. master cylinder is bad, change that then re-bleed the brakes again.
Old 12-19-2004, 01:14 AM   #11
eag182
There is a great topic - not sure where - about the noise most get when braking. Apparently easily fixed by some lubracation but I think you should look for that topic first.
Old 12-20-2004, 09:53 PM   #12
jwth2005
Brake fluid is full
Old 12-20-2004, 09:58 PM   #13
bluephoAm
It could be the hoses themselves since they are made of rubber.
