12-14-2003, 10:18 PM
I have a 2002 4 door gls w/o a sun roof. My question is if I could get my hands on a complete setup are the cars ready for it. I figured since there already seems to be a fuse for it in the panel that all I would need is everything else. But my biggest question is are the roof suports setup for it in all carsand they just cut out the sheetmetal for the sunroof or are there 2 differant roof stuctures depending on wether got got the sunroof or not. Any help woul be apreciated as I am now kicking my self in the asss for not goining with the one that was a year older with 5k extra miles but had the roof.
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
12-14-2003, 10:23 PM
I'm getting a Webasto sunroof in mine on Tuesday for $600 installed, but since it's a 2-door they can only fit in a power pop-up slide-back type. A 4-door can go all out with the one-touch power moonroof for a little over $1000 installed. Also, the webastos have a 5-year waranty against breakage or leaks, and it provides coverage for whatever gets ruined if it does leak (God forbid...)
that is a GREAT question, i have always wondered the same thing
12-14-2003, 10:24 PM
If you do it yourself the only problem you might have is correcting for the curve of the roof, left to right. It can leak pretty bad if you don't do it right.
12-14-2003, 10:43 PM
My main question is if I remove the head liner will i see an outline of a sunroof in the support structure of the roof
12-14-2003, 10:46 PM
probably, I don't think the  's over at GM would spend the cash on 2 different support frames.
12-15-2003, 01:32 AM
always been interested in one as well
I almost ended up buying a 99 camry 4 banger xle for the setup alone heh
I just need more windows to see out of!
smirking is important
follow the titans
12-15-2003, 02:18 AM
Kitteh is back!!!!
goto ww.americansunroofsinalfa.com
they made the sunroof i got in my car, actually fits better and looks cleaner than stock
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
12-15-2003, 02:29 AM
:huh?: how can u say it fits better and looks cleaner than stock?
12-15-2003, 08:13 AM
I'm with sweet on this one, nothing fits better than stock.
12-15-2003, 08:39 AM
Kitteh is back!!!!
well ok fits the same, but the inside seaming is cleaner. Ive seen the factory sunroofs on the headliner
01 Suzuki gsxr 750
12-15-2003, 09:21 AM
its gonna be the same price region with both
12-15-2003, 10:30 AM
Kitteh is back!!!!
I wouldnt agree with that completely, because there have been leaking problems that must be fixed on some of the sunroofs so thats kinda a .....issue
01 Suzuki gsxr 750
12-15-2003, 10:44 AM
The Founder
my factory sunroof doesn't leak, and i love it
12-16-2003, 12:27 AM
i was quoted $795 from Autotrim Design and Graphics in Appleton Wisconsin for a power sunroof(moonroof). im looking at spring to get one.
12-16-2003, 12:23 PM
It's better to get the sunroof with the car from the factory unless you want to worry about it leaking...speaking from experience. Had my alero come from the factory with the sun & sound package--less to worry about plus covered under warranty.
2002 Olds Alero Coupe-Sterling Silver 184k miles & running strong
12-16-2003, 10:19 PM
I install webasto/hollandia and ASC roofs. And to answer ALL yours questions, no there is not any sort of frame on roofs w/out a sunroof. Factory roofs will not work with cars without either. There is a beam right above the domelight on the alero with out factory roofs. We have to cut it out before install, run drain tubes at all 4 corners, then recover the headliner. All in a days work!
12-16-2003, 11:37 PM
thanks thats all i wanted to know
12-17-2003, 12:19 AM
the sunroof im gettin from Auto Trim Design comes with a 3 year 36,000 mile warranty.
