Old 12-28-2004, 07:32 PM   #1
AntAlero
Hey Guys
Twice in the past couple of week my car dosen't seem to start. I turn the key and the engine will not turn over at all, I turn again and the car will start. I thought it was the battery, but it seems to be fine. Any ideas??
Old 12-28-2004, 07:38 PM   #2
Could be you're fuel pump starting to go
Old 12-29-2004, 12:29 AM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
could be that or any number of stupid little things.
connection to the starter motor, or even the ignition switch, could be loose
cold weather w/ thick/dirty oil (when's the last time you changed it?)
also, if you have modded anything, what have you done?
If you've hooked up a sound system, you might be using too much juice the night before...just a thought. I'm sure some of the gurus here can deduce it down to a simple solution with more info. :thumbsup:
