Old 12-28-2004, 09:46 PM   #1
eag182
I'm aiming to install an amp in the Alero soon but need to know if anyone whose done this has had to put a new hole in their firewall to connect it to the battery.
Old 12-28-2004, 10:00 PM   #2
bigd6983
there are already grommets in the firewall for you to go through......if you want you can always drill another hole and install a grommet but thats up to you.......
Old 12-28-2004, 10:26 PM   #3
Screamin eagle
Screamin eagle's Avatar
Screamin eagle is an unknown quantity at this point
Send a message via Yahoo to Screamin eagle
Just poke a small hole through one of the ones that is there and squeeze the wire through that way it is still waterproof.
http://www.myspace.com/knoxy66
Screamin eagle is offline   Reply With Quote
Old 12-29-2004, 12:41 AM   #4
eag182
thanks!
Old 12-30-2004, 05:18 AM   #5
mikegett
mikegett's Avatar
be sure to add about a extra three feet of cable. I needed 17 feet to reach the far end of the trunk. I still would have liked to have another foot of play.
Old 01-16-2005, 03:10 PM   #6
xsavyor1
xsavyor1 is an unknown quantity at this point
I have 2 runs of 1/0 to the rear of the car. Just go through one of the gromits that is already there.
TEAM PRODIGY-TEAM CROSSFIRE-TEAM XS POWER
WWW.TEAMPRODIGY.NET
WWW.CROSSFIRECARAUDIO.COM
2010 BASS RACE WORLD CHAMPION 140.0DB - 149.9DB
2009 Bass Race World Champion 140.0-149.9db Class
xsavyor1 is offline   Reply With Quote
Old 01-28-2005, 07:15 PM   #7
eag182
Sub box is completed (sans carpet for now). Amp is hooked up. Works Great.
The boomage is fantastic.
The only thing i would like to change is the Head unit. The stock one lacks a ton of controls and this ninja wont stand for it. Also might need a capacitor, but the dimming is quite minor.
Thanks to everyone who help!
Old 01-29-2005, 12:46 PM   #8
mike2002
mike2002 is an unknown quantity at this point
Send a message via Yahoo to mike2002
fyi cap wont really help with dimming, spent the money on a H.O. alternator if you have a good battery, or if you have the stock POS battery, get a gel cell
2001 Alero GLS - Sold!
mike2002 is offline   Reply With Quote
Old 02-01-2005, 10:31 PM   #9
eag182
Its friggin cold outside, thank God for basements. I (finally) got some carpet adhesive + auto carpet so I'm off to finish carpeting my box:
Here's what it looked like before:
Old 02-01-2005, 10:32 PM   #10
eag182
Carpeting arrives:
Old 02-01-2005, 10:34 PM   #11
eag182
Cutout from Carpet. Enough lengths given on sides to overlap corners (you'll see later):
This is to cover all sides + top, sans bottom:
Old 02-01-2005, 10:35 PM   #12
eag182
And the top and side glued. Will finish rest whenever possible.
Old 02-01-2005, 10:35 PM   #13
Vtolds
H&B Shipping Agent
Vtolds's Avatar
That wood looks a little thin, I hope it stays together for you.
Old 02-01-2005, 10:39 PM   #14
eag182
Its .5", I thought it would be alright.
Old 02-01-2005, 10:42 PM   #15
mikegett
mikegett's Avatar
How do you like the gel cells. I have been curious about those. I have had to replace the battery twice (under waranty) and wandered if the gels would be worth going to.
Old 02-01-2005, 11:02 PM   #16
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Most people go with .75 inch but isnce it is one sub you will probably be alright.
Old 02-01-2005, 11:13 PM   #17
eag182
too late now B)
Old 02-01-2005, 11:33 PM   #18
mike2002
ive never really had a "system" in a car, not one to warrant upgrading the charging system. but my brother does competitions in his trucks (he's been through a few trucks by now) his biggest one was in his older expedition. he took out the 3rd row seating and put a huge ported box in for 4 12's, atomic audio ELE's. he had 4 american bass amps, 1200 (real) rms watts to each one. then his 4 channel running the front and rear components. god... i think we ran 2 0 gauge wires, i cant even remember. all i remember is first he put in a ohio generator alternator, and he was having tons of dimming problems still, so bad that at night the dash would get so dim you couldn't read it. then he threw in 2 more gell cells (scosche ones) and it made it much much better, it still dimmed, but not as bad
they dont usually have as much cranking amps, but you can run them way down, and then charge them and there perfectly fine, unlike a convental battery which doesn't like that
but in smaller systems they eliminated alot if not all of the dimming
he just started stocking somthing called a "batt cap" im not sure exactly what it is, bu its supposed to be a mix between a battery and capacitor, there not very big either....dont know alot about them
Old 02-02-2005, 04:29 PM   #19
eag182
Competition levels would give me a headache!
Update on carpeting: Here's the back of the box, upside down. I fudged on the overlapping, so perhaps I will get those rubber corner things. Its not completely done, obviously.
Old 02-06-2005, 01:32 PM   #20
eag182
I actually finished a few days ago, just forgot to post this:
