Old 11-18-2003, 01:29 PM   #1
Molson
Molson's Avatar
Really quite simple and is documented in your Owners Manual.
Open drivers side door.
Remove fuse panel.
Put key in ignition an turn to "ON" position (do not start).
Press the "RESET" button once (located inside fuse panel)
- Change oil light will flash -
Press the "RESET" button once more and you will hear a chime.
- Light will go off -
Key off the car, replace the fuse panel and you're all done.
Another way to do this, is to turn your key to the "on" position..very important-do not actually "start" the car. Put the gas pedal to the floor three times real fast, like within 5 seconds. Wait a couple seconds, and you'll hear the chime...reset done.
Old 01-23-2004, 11:12 PM   #2
Qcksilver
Qcksilver is an unknown quantity at this point
Send a message via Yahoo to Qcksilver
Is that quote for real?? I've never heard that before. Maybe I'm just gullable. It's interesting if nothing else. I wonder if it really works.
Qcksilver is offline   Reply With Quote
Old 01-24-2004, 08:59 AM   #3
Molson
Molson's Avatar
yes its real, I do it all the time. well, every oil change.
Old 01-25-2004, 01:18 PM   #4
wc_alero
Yeah it definitely works, I do that everytime I get my oil changed.
Old 07-28-2005, 04:02 PM   #5
ptrudel
Designated Drunk
*thread jesus alert*
is there any other way of resettin the damn thing? my gauges don't come on without the car actually started....disconnecting the battery don't work either
I'm baaaackk
Old 07-28-2005, 04:03 PM   #6
Crolero
turn to ON position and pump the gas pedal 3 (or 5) times. Same effect.
Old 07-28-2005, 04:26 PM   #7
Hpkittedalero
this also works on the low tire pressure warning light .......
