Old 01-07-2005, 11:54 PM   #1
hokay, i just got a few good ideas for using up all the LED's i just ordered, but i need some info from the fellow members.
1) is there a good place to wire interior lights into, so when it actually gets dark enough for my headlights to turn on and the map cubby turns on, the other lights i'm putting in will also click on?? How and Where?
2) Is there a spot on the Hood fuse block (or either of the others) to add a fuse block on?? i'm just getting tired of making a dumb electrical mistake and having to change a bunch of fuses or losing something important... (cig lighters, gauges..etc) i'd rather add my own and wire into it.
--More slightly off topic--
3) i've noticed that my rear view mirror vibrates....ALOT.... when i turn my radio up. its mostly from my soundstream 6.9's in the back. is there a good way of stopping that? and is that method just simply dynomatting the back deck?
ok, i'm done now..
Old 01-08-2005, 12:08 AM   #2
Screamin eagle
Screamin eagle's Avatar
Screamin eagle is an unknown quantity at this point
Send a message via Yahoo to Screamin eagle
I don't think using dynamat on your back deck will stop your mirror from vibrating. I've been trying for years to find a way to keep it from vibrating but as long as there is bass waves I think there is going to be some shaking.
http://www.myspace.com/knoxy66
Screamin eagle is offline   Reply With Quote
Old 01-08-2005, 01:49 AM   #3
AleroBloke
as long as the low frequencies are passing through and around your car cab, it will continue to shake, so to answer your question, No there is no way to stop it from shaking.
Old 01-08-2005, 01:56 AM   #4
Nik1128
Turn down your radio.
Old 01-08-2005, 10:17 AM   #5
^ thats not gonna happen. nice try though...lol
Old 01-08-2005, 11:33 AM   #6
bigd6983
ok, i'm done now..
you think thats bad, my rear view mirror rattles along with the two side mirrors outside the car, rattles so much i couldnt tell if their is a cop behind me lol.....
Old 01-08-2005, 12:21 PM   #7
Schimmel03
Senior Member
Schimmel03 is an unknown quantity at this point
Send a message via AIM to Schimmel03
I WIN! Mine rattles so bad that the rearview mirror actually vibrates off the metal tab glued to the window. Try and beat that. :P
<img src=\'http://www.supermotors.org/getfile/182743/fullsize/sig.jpg\' border=\'0\' alt=\'user posted image\' />
1999 Oldsmobile Alero
White
4 Door
74,000 miles
Twin Cam 2.4L
<span style=\'color:red\'>Let the modding begin!</span>
Current Mods: 2.3HO Intake manifold and Throttle body, Induction Dynamics intake, Unorthadox crank pulley, 15&quot; Kicker CVR, Pioneer Premier headunit, Optima Yellow Top battery, and LED Undercar Lights
Schimmel03 is offline   Reply With Quote
Old 01-08-2005, 12:40 PM   #8
eag182
Mine falls off and I don't even have a sound system yet.
I mean, come on, I'm not that hideous.
Old 01-08-2005, 12:46 PM   #9
lol, well this went off topic pretty quickly.
someone has to have figured out a way to prevent that...
and i guess no-one has an answer for the other questions...?
Old 01-08-2005, 01:39 PM   #10
simple solution, just take your rearview mirror off!
Old 01-08-2005, 01:41 PM   #11
oh for your first question, just tap into cubby hole light. thats where i tap into for any interior lighting that i do...ie/white gauges, needles, etc...that is your best bet
Old 01-08-2005, 04:32 PM   #12
Screamin eagle
Easier yet is to open up the center console and tap into the light bulb that lights up the little letters that tell what gear you're in.
Old 01-09-2005, 12:52 AM   #13
eag182
what? these are illuminated?
Old 01-09-2005, 12:59 AM   #14
Nik1128
lol. You've never noticed that before? Just the other day, I was thinking how worth less they were when iluminated.
