Old 01-13-2005, 06:22 PM   #1
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
Thumbs up
I was under there, couldn't find the drain for the radiator. Could someone tell me exactly where it is? The car is a 2001.
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 01-13-2005, 09:02 PM   #2
nguyen187
facing the car, lower righthand corner, little white piece, use a 1/4 extension to turn it, its not completely screwed in, so you just need to twist it a little then use some kind of pick tool to pull it out, make sure the cap for the reservoir is off! hope that helps.
Old 01-14-2005, 12:34 AM   #3
bigd6983
most people would agree with me when i say i dont recommend taking it off because there is a good chance it can break and you will hafta get a new one, if what you want to do is drain the coolant, most people just disconnect hoses.......
but what he saids right, thats where it is.....
Old 01-14-2005, 05:23 AM   #4
FrankNY
FrankNY's Avatar
Thanks, I was looking for a "petrooster" type drain. :thumbsup:
FRANK
2001 Alero GL
Old 02-08-2005, 05:16 PM   #5
Spy
it won't break... just be a man about it, and don't kitty around with it... get a good grip, twist like supposed to... and out it all goes..
Old 07-17-2007, 09:24 PM   #6
Seaaan
Seaaan's Avatar
Seaaan is on a distinguished road
Send a message via AIM to Seaaan
Alright I know this thread is really old, but I was draining my coolant from the radiator today... I sorta effed it up so to say.. I used the 1/4 extension like the haynes manual says to and loosened, but it was only dripping a little. Then I used pliers like it said and I had some issues and ended up tearing pieces of the plastic off so now I can't tighten or loosen it anymore. Are there any radiator drain valve replacements ?? I wasn't trying to take it off just loosen it like it said, but the plastic was just ripping off.. does anyone know where I can get a replacement or do I need to get a whole new radiator? thanks..
edit: alright i found the plug at autozone, but anyone know how to get a really ripped up/threaded radiator plug out??
Seaaan is offline   Reply With Quote
