Old 01-14-2005, 10:51 AM   #1
mike2002
mike2002 is an unknown quantity at this point
Send a message via Yahoo to mike2002
i turned my hvac knob, the one that selects where the air goes (on the right) and it just snapped, so its stuck blowing on my feet, which sucks because its -11f up here in minnesota and i need to defrost my windshield....
i have a feeling gm will make me buy the whole setup, anyone know? or anyone have a extra hvac knob i can get from you? i know alot of you switched to the blue ones the used in later years
2001 Alero GLS - Sold!
mike2002 is offline   Reply With Quote
Old 01-14-2005, 11:02 AM   #2
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
the blue ones are actually the stock ones, the black rubber piece was just taken off, as the knob itself is blue
ImSoBored is offline   Reply With Quote
Old 01-14-2005, 12:54 PM   #3
jonez
Bad news. I have a set but they are packed up in my move and are currently some where in the middle of the Pacific. If you haven't gotten any by then let me know.
Old 01-16-2005, 01:55 PM   #4
mike2002
thanks, ill try to find out if the dealer will sell me just one knob too, for right now, i pulled off the middle knob and put it over there, since its so damn cold i dont have any reason to change the middle one from anything but all the way hot. i can tell when i pull them off and put them somewhere else its kind of hard on them, you have to give it a pretty good pull to get it off, which is never good for cold plastic.
Old 05-22-2005, 08:34 PM   #5
El Pablo
03 Subaru WRX
El Pablo's Avatar
El Pablo is an unknown quantity at this point
Send a message via AIM to El Pablo Send a message via Yahoo to El Pablo
that is unless its a 04 in witch case its a ugly nasty white under the plastic, witch reminds me i gotta go look for the blue knobs
El Pablo is offline   Reply With Quote
Old 05-22-2005, 09:17 PM   #6
Grouch
it'll be the late 01's and up that have the white knobs underneath.
Old 06-08-2005, 08:55 PM   #7
rtgree01
I have a problem with the fan speed knob... It only works on speeds above the third setting.... I'd like to get it replaced....
Did anybody find a place that will sell the knob assembly? I tried Autozone.... and I don't want to buy the WHOLE 3 knob assembly....
Any thoughts?
Thanks,
Ryan
Old 06-08-2005, 09:10 PM   #8
Grouch
That's a bad blower motor resistor. Common problem. Here's how to fix it: http://invision.aleromod.com/index.php?showtopic=2306
Old 06-09-2005, 12:17 PM   #9
Alero04
i had that problem in the winter...it just snapped and wouldnt go to any other control other then the vents....dealership fixed it np...mines an 04 tho :P
Old 06-12-2005, 12:59 PM   #10
mike2002
i got a set of the blue ones from a member a while ago. you can tell by looking at them since they're made different that they wont snap in cold weather like my white ones. but i just got a new white one anyways, because with the rubber off, the blue ones were half impossible to turn. maybe the knobs are harder to turn on the 01+'s or somthing, because i had a heck of a time getting a grip on them
and with the rubber on, they dont stick out as far as my white ones, making them harder to turn. and they look/feel alot cheaper.
