12-18-2003, 07:55 AM
Yesterday when i started my car, the first 2 blower speeds would not work. Has anyone had this problem? If so let me know. Thanks
Pheenz Motorsports Founder
12-18-2003, 08:30 AM
I have this same problem, I think it is a common problem with alero's.
12-18-2003, 08:33 AM
Yup yup, you're not alone. It's the blower motor resistor. Less than $20 from your friendly local Olds dealer (or Pontiac if Olds is bye-bye). You'll find instructions on here how to replace it, it's not hard, just uncomfortable. You'll have to get under the dash on the passenger side.
12-18-2003, 08:36 AM
YOU NEED A BLOWER MOTOR RESISTOR. iT LOOKS LIKE A CIRCUIT BOARD AND GOES UNDER THE PASS. SIDE DASH IN THE AIR DUCTS. ABOUT $30 AT YOUR DEALER.
12-18-2003, 11:14 AM
Thanks alot. Ill get that ordered.
12-19-2003, 09:45 PM
Mine actually only works on high. Pretty damn annoying. I'll fix it one of these days.
12-20-2003, 12:30 AM
yeah , mine did that to me too. I fixed it,but it was a real pain in the butt.
The part was cheap and I installed the new one in about an hour or two.
It goes under the panel in the passengers side, ALL the way back to the firewall. you need a screw driver for the little screws that hold the plastic panel, then you have to pt your head where your feet go , basicaly you sit upside down and reach all the up to the firewall. it looks like a little green plug. You need to remove this with an elbow adapter because the 2nd screw is hard to reach with a straight one, then just slide the new one in , and it should work.
Don't bother going to a mech. for 30 bucs an hour when you can do it in your driveway on afternoon.
Part #: 15359314
GM List: $23.09
GMPartsDirect.com: $11.54
12-20-2003, 01:28 AM
The exect thing happened to me. the first 2 speeds. but guess what, WARRENTY=FREE. so i didnt spend a dime
