Old 01-24-2005, 09:14 PM   #1
TribalAlero2000GL3
All need to know is how many LEDs can i wire off of one wire striaght from the battery (fused). (All of the LEDs having resistors). kinda confused with the whole voltage and series parrallel wiring etc.
Old 01-24-2005, 09:41 PM   #2
TribalAlero2000GL3
From researchin the internet i found that u can wire as many LEDs and u want in parrallel (all + together all - together, with resistors on each LED) as long as their the same wattage consumption. if anyone can confirm this or lemme know diffrently?
Old 01-24-2005, 09:58 PM   #3
brim
brim's Avatar
based on the basic led max which is 3v? I believe, you can wire 4 together in a series
smirking is important
follow the titans
Old 01-24-2005, 10:02 PM   #4
brim
brim's Avatar
check here for more info
http://www.oznium.com/forum/search.php?mode=results
follow the titans
Old 01-24-2005, 10:16 PM   #5
TribalAlero2000GL3
thanks dude but what if u want to run more then 5 im talkin bout runnin like 30, thats where im confused i undertood running 4 but what about anything after 4
Old 01-24-2005, 10:20 PM   #6
eag182
Do you need to know the resistence equations?
Old 01-24-2005, 10:49 PM   #7
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
Use this to calculate resistor size needed
ImSoBored is offline   Reply With Quote
Old 01-24-2005, 11:53 PM   #8
brim
brim's Avatar
you can essentially run as many as you want off a single 12v line if they have resistors to them
follow the titans
Old 01-25-2005, 02:11 AM   #9
bigd6983
he wants to know how many you can run in parallel, you can run as many as you want, the more you run the bigger the wire you will need, but led's dont pull hardly any current......
like they said you can bypass resistors pretty much all together by wiring 4 in series then wiring another 4 in parallel........
id stick with what ur doing and just throw them all in parallel.......
Old 01-25-2005, 03:52 PM   #10
yeah, just solder the resistors on each, one wire to all the grounds, and one wire to all the hot's and your done. there isn't a limit unless your doing them in series w/o the resistor.
Old 01-25-2005, 05:04 PM   #11
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
series parallel is the way to go. (Hybrid circuits are fun...but I don't wanna mess with them in my car)
Old 01-25-2005, 05:35 PM   #12
TribalAlero2000GL3
Thanks guys thats what i wanted to know,
mod u can close/ delete this now
Old 01-25-2005, 09:44 PM   #13
turtles_ride
What do i do if i have all the LEDs i want, but don't want to use any resistors at all with them? Can i hook 4 3V LEDs in series, and then hook these groups of 4 together in parallel? Also, i think they get dimmer the more you hook up don't they, because more of them draw more current and put more load on the circuit, or is that only if they have resistors on each one?
Old 01-25-2005, 10:06 PM   #14
you'd have to connect the four hots and grounds together to get 12V lead, then connect each set of 4 to the power and ground. and they shouldn't get dimmer, regardless of how many you use. your battery is cranking out a TON more power then LED's could ever drain.
Old 01-26-2005, 02:26 AM   #15
bigd6983
no you can them in series, the negative off one gets hooked up to the positive on the other, with four it will be able 2 handle 12 volts.......any more than four in series and the nominal voltage that set of leds needs goes up but ur battery is always putting out around 12 volts, never changes.......
thats why they dim, not enough voltage to the bulb or led......
and current isnt given to the led, current is what the led is pulling from the battery.........when putting led's in series the current is staying the same but the voltage is changing, when in parallel the current is changing not the voltage.......
Old 01-26-2005, 11:59 AM   #16
eag182
On another note, what wire guage do you all recommend when hooking up lcds?
Old 01-26-2005, 01:16 PM   #17
bigd6983
like a monitor? well it depends on how big....im sure ud be fine with 16 or 18 gauge......
Old 01-26-2005, 03:19 PM   #18
Crolero
So if you put 2 led's together + with + - with - that means that they pull 6 Volts from the battery and will need resistors not to get the entire 12 volts (or BOOM). If you have 4 led's then your pulling and getting max voltage from the battery wich is 12 Volts. Is this correct...?
Old 01-26-2005, 03:30 PM   #19
bigd6983
no croalero.......if u match + with + and - with - it will still only be able 2 handle 3 volts......if you do 4 led's...... + - + - + - + - and hook the end positive and negative to ur 12 volts and ground you will be good to go, no resistors needed.....
