Old 02-05-2005, 03:52 PM   #1
OK I installed a new LED for the car alarm today and took everthing apart anyway so here is a "How To" for the A/T boot installExtenstion of Alerospeed's Parking Boot install
If your just doing the boot for the A/T you only have to pop out the radio bezel and the Tranny Bezel.
Old 02-05-2005, 03:54 PM   #2
NO PICTURE
To remove the ETS switch find the tab at the bottom of the switch. Gently put a small flat head screw driver under the tab and turn. Connection will just pop out.
Under the PRND321 there is a light, just grab the base and twist gently.
Old 02-05-2005, 03:58 PM   #3
Remove the accordin pieces by squeezing the tabs together underneath and they will all fall out. Be careful becasue they are very fragile and you will need the biggest one for later.
Old 02-05-2005, 04:00 PM   #4
Undo the 7mm bolts on the bottom that hold on the PRND321
Place the vinal over the hole and screw the bolts back in place
Old 02-05-2005, 04:03 PM   #5
Make it tight but leave some slack
Old 02-05-2005, 04:04 PM   #6
Safety first
Cut away around the light port
Old 02-05-2005, 04:06 PM   #7
This is why you need the biggest accordin piece. If you leave it out it will look like crap
Old 02-05-2005, 04:07 PM   #8
Put everthing back in place in reverse order and you're done :thumbsup:
