Old 02-08-2005, 02:12 AM   #1
Schimmel03
Senior Member
Schimmel03 is an unknown quantity at this point
Send a message via AIM to Schimmel03
I'm in the process of building my custom enclosure in my spare tire well and I am at a stand still. Reason being, if I want to flush mont my sub with the trunk floor I'll only have 1/8th inch between the back of the box and the bottom of the sub. How much space is there supposed to be here? Is there a minimum? Any help you guys could give me would be great! Thanks!!
Eric
<img src=\'http://www.supermotors.org/getfile/182743/fullsize/sig.jpg\' border=\'0\' alt=\'user posted image\' />
1999 Oldsmobile Alero
White
4 Door
74,000 miles
Twin Cam 2.4L
<span style=\'color:red\'>Let the modding begin!</span>
Current Mods: 2.3HO Intake manifold and Throttle body, Induction Dynamics intake, Unorthadox crank pulley, 15&quot; Kicker CVR, Pioneer Premier headunit, Optima Yellow Top battery, and LED Undercar Lights
Schimmel03 is offline   Reply With Quote
Old 02-08-2005, 05:09 PM   #2
mikegett
mikegett's Avatar
Your speaker doesn't care where the air volume comes from. The key is to determine what volume is needed and be able to incorporate it into the area. Sometimes it may be easier to change the type of box you were going to use.
Old 02-08-2005, 11:00 PM   #3
slowandlow
slowandlow's Avatar
there is a minum space depending on how your sub is vented aka vc
Old 02-11-2005, 04:20 AM   #4
BLK03GXS
BLK03GXS's Avatar
Some subs do requre a certin amount of Pole piece venting, my recomdation would be to rase it a lil bit to gain closer to half an inch of room in that area.
Old 02-11-2005, 01:45 PM   #5
Schimmel03
Senior Member
Yeah, I completely changed my design. I will be holding this off for a few weeks until it gets warm enough to work with the garage door open. Thanks for all the input. It really did help!
White
4 Door
74,000 miles
Twin Cam 2.4L
