Old 02-19-2005, 04:21 PM   #1
jordan
jordan's Avatar
jordan is an unknown quantity at this point
Thumbs up
I am getting alot of what sounds like knocking noises over bumps from my front and rear suspension.
First of all. The front end has new struts and mounts so I know that's not it. Could worn out stabilizer links on the front cause bumping/knocking noises over bumpy roads??
I live in Manitoba so driving over all the icy roads this time of year causes lots of noise. I can even feel it a bit like a vibration through the floor.
Also how do you check to see if the links need replacemen?
And the rear end is another story since nothing is new back there and I 'll get it checked at a dealership.
Any tips though on how they check the suspension for worn out components???
I figured with some info on how to check for worn out stuff, I could save on paying for the inspection
Thanks
<a href=\'http://www.winnipegheights.com\' target=\'_blank\'>Winnipegs Finest</a>
jordan is offline   Reply With Quote
Old 02-19-2005, 11:59 PM   #2
bigd6983
im sure they look for play whether its vertical or horizontal........worn out bushings......things like that....
Old 02-21-2005, 12:17 AM   #3
Wildman
Wildman's Avatar
Wildman is an unknown quantity at this point
I had a tie rod end that was giving me a similar sound when hiting sharp dips or bumps. plus it was making lots of roadnoise.
CAI - Borla Cat-back - S&S Headers - DHP - AFPR
Wildman is offline   Reply With Quote
Old 02-21-2005, 01:52 AM   #4
forbidden
Graphix GOD
forbidden is an unknown quantity at this point
Send a message via AIM to forbidden Send a message via Yahoo to forbidden
I would check the tie rods... one way to check it is jack it up grab the wheel and try to move it side to side like shaking it. if it moves then the tie rods may be worn.. the cost about $65 and a dealership and they are not hard to put on.
forbidden is offline   Reply With Quote
Old 02-21-2005, 07:05 AM   #5
Mine just creaked and squeaked so I replaced the struts
Old 02-21-2005, 10:32 AM   #6
CaperAlero
I think its the Canadian winters. Mine has been knockin' and a popin' and a squeakin' since my first winter with her (new). I've had everything checked out a dozen times, and now just live with it. When it gets warmer (for a few months) it quiets down.
Old 02-21-2005, 10:41 AM   #7
^^ Oil in the struts frezze. That's the squeaking
Old 02-23-2005, 11:34 AM   #8
NATIVE
it may also be your cv joints up front. my roommate told me that in Alaska
you are required to replace your cv joints every 6 months by law. because of
the constant cold weather. but i don't know how true that is he is from Alaska
so he probably knows. my right front just went and it makes small popping
noise when on a not so bumpy road. my susepension squeaks also seem to go
away when the weather is warm.
