Old 02-20-2005, 10:38 PM   #1
Ok the driver's side window was working fine on Saturday before I left to go to my g/f's house.
45 minutes later, I pull up and roll down the window and the window will not go down. I heard nothing, not even the click of the switch.
This morning and all day today, it worked fine
Sounds like a switch to me. Am I right?
Old 02-20-2005, 10:40 PM   #2
jackal2000
jackal2000's Avatar
might have a bad spot on the motor, smack dat bia once or thrice and it should work. its happened to me twice so far.
Old 02-21-2005, 07:36 AM   #3
wait until it happens again and when it does, take a shot at the motor, if it works, then its the motor, otherwise the switch is the cheapest alternative.
Old 02-21-2005, 10:34 AM   #4
OK where do I hit the door? Exaclty where is the motor?
Old 02-21-2005, 10:44 AM   #5
jackal2000
jackal2000's Avatar
if you are sitting in the driver's seat, the motor is towards the lower right corner
Old 02-21-2005, 10:47 AM   #6
above or behind the speaker?
Old 02-21-2005, 12:42 PM   #7
rowdygls
rowdygls is an unknown quantity at this point
Send a message via AIM to rowdygls Send a message via MSN to rowdygls Send a message via Yahoo to rowdygls
believe it or not it could be the cheap little plastic piece that holds the window. thats how my passenger side worked for a while until it broke completely.
my cardomain: http://www.cardomain.com/ride/605233Alero
Chapter Member
rowdygls is offline   Reply With Quote
Old 02-21-2005, 01:52 PM   #8
jackal2000
jackal2000's Avatar
if i remember correctly from when i had my door apart the motor is right about here....
Old 02-21-2005, 10:41 PM   #9
Nik1128
I have the same problem. Its not the switch. The first thing I did was buy a new switch, and it didn't do anything for it. All I do is just take the door trim off and bang on the motor.
