Old 02-22-2005, 12:20 PM   #1
coblepots
Alright, i want to purchase some rims in the next couple months. However i can never find any good deals on 115X5 rims, only 114.3X5. What size ring should i get for the hub or would i be fine without one?
Old 02-22-2005, 01:10 PM   #2
1WhiteOSV
Here ya go man..this should answer your question:
Hub Centric Rings
They aren't that cheap but the company is very nice...I lost one in the process of taking my wheels off for the winter and just emailed them telling them I "broke" one and they gladly sent me a new one for free (didnt even charge for shipping) and I got it about a week or 2 later.
Old 02-22-2005, 01:45 PM   #3
misslindseysue
You can also get a set of four hub rings for about $15 at Discount Tire.
Old 02-22-2005, 02:03 PM   #4
johny_boy32
johny_boy32's Avatar
make sure you need them first though. I got wheels that were 114.3 and I didn't need them and I know of a bunch of guys on this site that have the same bolt pattern(114.3) and they didnt need them either.
Old 02-22-2005, 02:05 PM   #5
jackal2000
jackal2000's Avatar
^^^myself included
Old 02-22-2005, 02:38 PM   #6
Crazytaxi37
The Dark Lord
Crazytaxi37's Avatar
Crazytaxi37 is an unknown quantity at this point
Send a message via AIM to Crazytaxi37
Me too.
Crazytaxi37 is offline   Reply With Quote
Old 02-22-2005, 02:43 PM   #7
coblepots
Thanks a lot guys. Also, i have decided to do my interior this summer when i get back from college. I was planing on using vinyl die on the dash as krylon fusion supposedly only works on hard vinyl such as the grills and what not. Where can i get the die and about how many cans do you think i need? Also, i was going to replace the carpet with a black marine carpet. Should i just overlay the new carpet on the old one and use a like double sided tape or appolstry glue? Or do i have to rip out old carpet first? Thanks in advance.
Old 02-22-2005, 03:40 PM   #8
johny_boy32
this thread just took a 360. You should start a new thread with a new title so the people that know something about this will look at it. In my personal opinion, I would take the old carpet out and lay the new stuff in its place. If you lay it over the top of the original stuff, you may have problems with bulging, fraying, and it coming loose.
Old 02-22-2005, 04:39 PM   #9
b-spot
b-spot is an unknown quantity at this point
Hub rings have nothing to do with bolt pattern, but the hub bore size. Stock wheels have a hub bore that exactly matches the hub on your vehicle. Aftermarket wheels often have bigger hub bores to allow them to fit on more vehicles, and you use hub rings to fill the space to take the weight off the lugs and back onto the hub.
If I did went to college...
b-spot is offline   Reply With Quote
Old 02-22-2005, 04:53 PM   #10
forbidden
Graphix GOD
forbidden is an unknown quantity at this point
Send a message via AIM to forbidden Send a message via Yahoo to forbidden
114.3 works with no problem!!!!!
forbidden is offline   Reply With Quote
Old 02-23-2005, 12:54 PM   #11
Sundayalero
Sundayalero is an unknown quantity at this point
Exactly! Always use the rings with aftermarket wheels.
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
Sundayalero is offline   Reply With Quote
