Old 12-23-2003, 04:34 PM   #1
shockz
OK. So I was in a crash a couple weeks ago and had to get new headlights.
So today I bring the car home and I get out and I see that the new head lights are now fogged up. My old ones never fogged up, and I just wanted to know what causes it and how I can fix it.
Thanks
- AleroGL02
Old 12-23-2003, 04:38 PM   #2
r53silver91s
r53silver91s is an unknown quantity at this point
The caulking could be dried out, but I'm not positive, I had this problem after I cleared my corners, so I just caulked the crap out of it and its been fine, just looks like crap when I pop the hood so maybe someome else will tell u a more intelligent way.
<a href=\'http://members.cardomain.com/r53silver91s2\' target=\'_blank\'>http://members.cardomain.com/r53silver91s2</a>
<img src=\'http://invision.aleromod.com/uploads/post-24-1088131656.gif\' border=\'0\' alt=\'user posted image\' />
r53silver91s is offline   Reply With Quote
Old 12-23-2003, 04:45 PM   #3
Final-Reality
There's moisture in them, the caulking isnt fully sealed
Old 12-23-2003, 04:52 PM   #4
shockz
Should I take it back to the body shop, or is it something that I could fix?
Old 12-23-2003, 04:58 PM   #5
No I would suggest you do it yourself. You never know what hidden charges a bodyshop will have.
Use caulk or a head gasket sealer
Old 12-23-2003, 05:09 PM   #6
havik
You can find instructions that'll assist you in doing it yourself here: http://invision.aleromod.com/index.php?showtopic=17
While you at it, you might as well clear your corners
Old 12-23-2003, 05:11 PM   #7
AnderbrA
AnderbrA is an unknown quantity at this point
Send a message via MSN to AnderbrA Send a message via Yahoo to AnderbrA
clear them biznatches!!!!!
AnderbrA Innovations
Custom Automotive Lighting
www.anderbrainnovations.com
07 Cadillac STS V8
07 Mitsubishi Galant ES
00 Olds Alero - Parts
02 Lincoln LS V8 Sport - RIP
AnderbrA is offline   Reply With Quote
Old 12-23-2003, 05:16 PM   #8
shockz
Thanks for the guide.
I think about clearing them, I kind of like the yellowness.
Old 12-23-2003, 05:41 PM   #9
freeze12
Also check the foam gasket on the bulb sockets as that is what was wrong with mine. Also make sure the shop put the bulb sockets in straight & not roostered.
...Dan...
Old 12-23-2003, 05:56 PM   #10
shockz
Will do.
Old 12-23-2003, 08:43 PM   #11
Travis99Alero
make sure the 2 rubber "boots" that cover the hole where the headlight go in are there too.
Old 12-23-2003, 09:57 PM   #12
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
yeah, might as well clear the corners, or if it is old caulk then just remove the old caulk and redo the whole thing
ImSoBored is offline   Reply With Quote
