Old 03-06-2005, 03:41 PM   #1
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Anyone know of any sites with direction and pictures of custom sub boxes?
Old 03-06-2005, 03:45 PM   #2
eag182
writies thread or http://web.njit.edu/~cas1383/proj/Glassing2/index.htm
Old 03-06-2005, 03:51 PM   #3
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Good site but not exactly what I am looking for, I want a site with directions to just plain Sub Boxes so I can make a custom exact box for the subs I buy plus it will be way cheaper to build then buy.
Old 03-06-2005, 06:57 PM   #4
eag182
Yea I built a simple one too and regret it now, I definitely wished I had looked at fiberglass earlier, so.....
Old 03-06-2005, 07:19 PM   #5
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Cant I alwasy biuld a wood one and instead of carpeting it Cant I put Fiberglass Body filler on it and paint it all up? but I probably will just carpet it, if I happen to biuld one. I actaully have 2 10 inch sub boxes I guess I could use but I would wanna make them different I have a Idea of recessing the amp in between the subs.
Old 03-06-2005, 07:48 PM   #6
eag182
For me its not about having the glassed look but rather relocating the sub to the recessed left and right parts of our trunk, like writies.
Old 03-06-2005, 09:40 PM   #7
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Damn is it hard to take Carpet of from old boxes. I just took the last 1.5 hours just doing one box and I didnt even do the bottom. THe boxes are made of only 1/2 in MDF, so I think probably cover the boxes in either another 1/4 inch of MDF or maby if you guys think it will work maby just a 1/8th inch of what my dad calls Luna Board, to just cover the old boxes you and to do the recessed amp, or do you think it would rattle a tad bit?
Old 03-07-2005, 01:15 PM   #8
Vtolds
H&B Shipping Agent
Vtolds's Avatar
I started my sub box it is very rough atm. It became quite aparent that the amp wont fit in between 2 10inch subs with the 39inches of trunk space I have, so I plan on mounting the amp on the back. What do you guys think? do you think that the wood I used will rattle to much? I think it is pretty solid, I plan on just leaving a Dead spot in Between the subs but it will be all covered up front and back. Anyone know a good site to buy BLACK carpetting and spray adhesive?
Old 03-07-2005, 01:29 PM   #9
jamcllw
Here's some carpet:
http://www.partsexpress.com/pe/showdetl.cf...tnumber=261-700
For the adhesive I'd go to the nearest Home depot or lowes. Part Express has it but you can get it cheaper from one if the other places.
Old 03-07-2005, 02:03 PM   #10
AGT
AGT's Avatar
What did you make it out of?
Have a good day
Old 03-07-2005, 02:05 PM   #11
Vtolds
H&B Shipping Agent
Vtolds's Avatar
The Boxes are 1/2 inch MDF they are old boxes I just stripped the carpet off From and just attached them together with 1/8th inch Luna Board the stuff was I talking about a couple posts up.
Old 03-07-2005, 02:37 PM   #12
AGT
AGT's Avatar
oops missed that part haha....I am a very visual guy...just ask all my ex girlfriends
Have a good day
Old 03-07-2005, 05:30 PM   #13
wrightie
wrightie's Avatar
wrightie has a little shameless behaviour in the past
Dood no offence but that is CHAP
wrightie is offline   Reply With Quote
Old 03-07-2005, 06:54 PM   #14
racin4JC
racin4JC's Avatar
racin4JC is an unknown quantity at this point
You might have a vibration problem with that 1/8 in. stuff. Also I have heard it isn't good to mount amps on the sub box because they rattle so much it will ruin the amp.
racin4JC is offline   Reply With Quote
Old 03-07-2005, 07:44 PM   #15
jonez
Here is a site that is very useful. http://www.glassmanscustomforum.com/
Old 03-07-2005, 09:50 PM   #16
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Yeah it is CHAP <_< It is very rough atm as I said, I have pretty extensive wood working skills and I also have about 2 months before the Subs and amp will be bought so I am sure it will be done by then. Do you think I will need ports or should I leave then like they are with no ports?
Old 03-07-2005, 10:17 PM   #17
mikegett
mikegett's Avatar
Unless you know what you are doing, do not port the box. Not all subs will work well in a ported enclosure and wrong port lengths can cause drastic peaks in the sub enclosure efficiency.
Old 03-07-2005, 10:21 PM   #18
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Thanks I'll keep the box as is, makes it easy then all I ahve to do is close that big whole up in the middle and I will be almost dont
Old 03-07-2005, 11:34 PM   #19
slowandlow
slowandlow's Avatar
i like 3/4 mdfb and dubble it up on the baffel. so you can resess the sub.
Old 03-08-2005, 01:51 AM   #20
AGT
AGT's Avatar
What kinda subs you puttin in there?
Have a good day
