Old 03-12-2005, 03:49 AM   #1
Spilner521
Boost Guru
Spilner521's Avatar
I was just lookin on one of the j-body forums and a bunch of guys over there say that if the stock MAP sensor sees boost it will throw a check engine light. is this true? and if so can a check valve be used to avoid this?
Old 03-12-2005, 11:20 AM   #2
FormulaNERD
wouldnt you be boosting after the map? i dont know if stock map's are even able to register air that compressed.
Old 03-12-2005, 12:14 PM   #3
Spilner521
Boost Guru
Spilner521's Avatar
the map has a vacuum hose that connects directly to a port in the intake manifold right below the throttle body so that it reads all the manifold pressure. so you'd be boosting pretty much right into the map. but yeah thats what i was thinking....that the stock one can't read boost at all..just vacuum. but if it does throw a code can that be eliminated with a check valve in the vacuum line?
Old 03-12-2005, 08:12 PM   #4
nguyen187
yeah just throw a check valve on it, thats what i did and it werks fine.
Old 03-13-2005, 02:13 AM   #5
Spilner521
Boost Guru
Spilner521's Avatar
awesome..thanks :thumbsup:
Old 03-13-2005, 10:58 PM   #6
Oldsman
Owner
Oldsman's Avatar
yep 2 check valves inline.
our stock maps are a 1 bar which is up to 0 boost.
Beware of the BackStabber
Old 03-13-2005, 11:29 PM   #7
Spy
gm supercharger reflash..... 2bar map.... 320cc injectors... no check valve needed and done right.
Old 03-14-2005, 12:31 AM   #8
FormulaNERD
1 bar is up to 14.5 psi.
Old 03-14-2005, 02:28 AM   #9
Spilner521
Boost Guru
Spilner521's Avatar
Originally posted by FormulaNERD+Mar 14 2005, 12:31 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (FormulaNERD @ Mar 14 2005, 12:31 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Oldsman@Mar 13 2005, 09:58 PM
1 bar is up to 14.5 psi. [/b][/quote]
1 bar is 14.7 psi which is atmospheric pressure aka 0 boost. anything over 14.7 psi, is boost. the the stock map sensor only reads up to 1 bar and nothing over that. so you'd need a 2 bar map to read up to double that. so a 2 bar map can read up to 29.4 psi...which includes your 14.7 psi atmospheric pressure and up to 14.7 psi of boost from the turbo.
Old 03-14-2005, 02:30 AM   #10
Spilner521
Boost Guru
Spilner521's Avatar
2 bar map and bigger injectors are easy to get.....but where would one aquire the gm supercharger reflash??
Old 03-14-2005, 02:33 AM   #11
FormulaNERD
Originally posted by Spilner521+Mar 14 2005, 01:28 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Spilner521 @ Mar 14 2005, 01:28 AM)</td></tr><tr><td id='QUOTE'>
1 bar is 14.7 psi which is atmospheric pressure aka 0 boost. anything over 14.7 psi, is boost. the the stock map sensor only reads up to 1 bar and nothing over that. so you'd need a 2 bar map to read up to double that. so a 2 bar map can read up to 29.4 psi...which includes your 14.7 psi atmospheric pressure and up to 14.7 psi of boost from the turbo. [/b][/quote]
sounds logical to me....
but why do 1.2 bar ecu programs for vw's boost at 17-18 psi? wouldnt it be a higher "bar" than that?
Old 03-14-2005, 04:08 AM   #12
Spilner521
Boost Guru
Spilner521's Avatar
when you're talkin about turbos running "1 bar" or "1.2 bar" of pressure, it reffers to how much boost it produces beyond the level of 14.7 psi atmospheric pressure. i dont know specifically about the vw engine, but i'm guessing the 1.2 bar program you mention sets the turbo to run at 1.2 bar.....which, coincidentally, is 17.64 psi of boost, right there in your 17-18psi range. so that engine probably uses a 3 bar map sensor, or something close to it, which measures up to 44.1 psi...14.7 atmospheric and up to 29.4 psi of boost :thumbsup:
Old 03-14-2005, 11:36 PM   #13
Spy
Originally posted by Spilner521+Mar 14 2005, 07:30 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Spilner521 @ Mar 14 2005, 07:30 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Spy@Mar 13 2005, 11:29 PM
2 bar map and bigger injectors are easy to get.....but where would one aquire the gm supercharger reflash?? [/b][/quote]
a dealership that's not a bitch about reflashing your computer with an easily accessable reprogram.
Old 03-28-2005, 02:41 AM   #14
Spilner521
Boost Guru
Spilner521's Avatar
what exactly does the gm reflash reprogram the ecu to do? anyone know?
Old 03-30-2005, 12:20 AM   #15
Fast Eddie
educated best guess....Definately expands the fuel map to account for the larger MAP sensor, I believe it adds some advance, probably plays with the auto's shift points, and hopefully, but doubtful, expands the resolution on the ignition system, also most definately adds some new code to the emission control system, esp. the post head O2 sensors.
I'm on a boat.....
Old 04-01-2005, 02:01 AM   #16
nguyen187
Fast Eddie you are pretty much on the right track except it doesn't advance the timing but rather pull it back, and from what i heard it pulls it back pretty significantly!
Do they have a reprogram for the Autos?
Old 04-01-2005, 07:13 PM   #17
Oldsman
Owner
Oldsman's Avatar
yes they do
Old 04-01-2005, 09:01 PM   #18
Spilner521
Boost Guru
Spilner521's Avatar
I've heard from some of the j-body guys that they can only reflash ecu's from 2000 and up models. true or false?
Old 04-01-2005, 09:50 PM   #19
Oldsman
Owner
Oldsman's Avatar
that is true.
they made some changes inbetween 99 and 00
Old 04-01-2005, 11:41 PM   #20
Fast Eddie
I would have guess they would pull timing to prevent detonation but from what i saw somewhere, maybe JBO, i could have swore someone said it added timing O well logic dictates it pulls timing so I will go with that.
I'm on a boat.....
