Old 03-13-2005, 07:07 AM   #1
Pacho
i'm going to be applying some spectrum v3 in my car under the rear side windows and i have tried to take the seatbelt off but the bolt is not budging. For anyone that has removed the actual seat belt bolt piece, did you use a hex key or an electric tool to remove it?
Old 03-13-2005, 01:35 PM   #2
FantomForceCustoms02
FantomForceCustoms02's Avatar
FantomForceCustoms02 is an unknown quantity at this point
Send a message via AIM to FantomForceCustoms02
In the front. The bolt on the floor is a 50 torx key. You dont need any electrical tools just a lot of strength. After you take off the plastic pieces on the side you'll need a 1/2 inch ratchet. These are also in there very well. You gotta apply a lot of pressure to break them loose. Then there is a metal bracket, just get some pliars and pull down it will pop right out. Then just put the plastic pieces back in and youre set.
In the back. The bolt is 1/2 inch. Just pull hard to break them loose.
I dont think this is supposed to be in the How-To section. Some mod may have to move it.
www.fantomforce.com
I like mine SHAVED
Be my friend...
http://www.myspace.com/fantomforce
FantomForceCustoms02 is offline   Reply With Quote
Old 03-13-2005, 04:14 PM   #3
bigd6983
if you are having trouble try a breaker bar, some people just dont have the strength and need these......
