Old 03-19-2005, 02:21 PM   #1
Crolero
After Rev posted his cleaned calipers i thought i might do mine as well. After seeing how new they can look i just had to try. (thanx Rev :thumbsup: )
I was gonna do the rotors as well but it started to rain.
This is what they looked like before
And here is after
Old 03-19-2005, 02:41 PM   #2
nice and shiny. gonna paint 'em or are you just get'n them shiny and clean?
Old 03-19-2005, 02:53 PM   #3
Crolero
was thinking on painting them white but after i cleaned them today i saw that the silver matches my car more.
Old 03-19-2005, 05:21 PM   #4
eag182
What did you use? if sandpaper what grit?
Old 03-19-2005, 05:56 PM   #5
eag182
im gonna use steel wool. that sound good?
Old 03-19-2005, 06:49 PM   #6
Crolero
i used a steel wool tool and some strong grit sandpaper. dont remember the number, you'll need a lot of elbow greese. Most of the crap comes off easy its just the small places are hard to reach.
Old 03-19-2005, 07:02 PM   #7
Skiboarder311
Skiboarder311's Avatar
Skiboarder311 is an unknown quantity at this point
Send a message via AIM to Skiboarder311
wow dood now thats some love for ur ride
i mean my car was my baby, but never in my life would i have spent 3 hours cleanin the brake calipers.
http://www.Clutchitup.com
Skiboarder311 is offline   Reply With Quote
Old 03-19-2005, 08:27 PM   #8
|Rev|
glad I could be an inspiration
and man my arm was soooore and tired after the cleaning lol!
Old 03-19-2005, 09:25 PM   #9
OpalaAlero
I'm gunna paint mine tuesday, and I sure as shat don't feel like spending 3 hours to clean em first.
Old 03-19-2005, 09:37 PM   #10
slowandlow
slowandlow's Avatar
what if you poloshed them and made them look all shiney?
Old 03-19-2005, 10:08 PM   #11
mikegett
mikegett's Avatar
You will still want to paint them clear or the corrosion will build up again. If you have a wire wheel put a brass brush on the end. they cost about four dollars and pollish with low abbrasion. If not, dremel makes a few attachments for polishing as well. They just take longer.
A small suggestion is to rebuild the caliber while it is out. The rebuild kit is cheap and might save future problems with worn seals.
Old 03-20-2005, 12:15 AM   #12
bigd6983
man the calipers look so nice when you clean them.........when i threw on the rotors i cleaned them up a bit and man they look good.......
Old 03-20-2005, 02:26 AM   #13
|Rev|
it will look 300X better if you atleast get a wire brush and get the tough crap off before you paint them.
This last time was the second time I painted my calipers, I had to replace the ones I replaced before, and this time it look soooo much better since I cleaned them first
Old 03-20-2005, 06:35 AM   #14
Crolero
Yea, i woke up this morning sore as all hell. It was worth it though.
Sould i use a clearcoat paint just to protect it?
Old 03-20-2005, 12:40 PM   #15
rmulax19
they make drill bits and dremel attachments where there's a circular piece of metal with steel wool on the tip of it kind of like this:
%%%%%%% <---steel wool
---------------- <---metal circle
| <---metal stick thingy
makes things like that a million times easier. the drill or dremel does all the work for you. you'll still need sandpaper or a piece of steel wool to get in the spots that the tool can't reach but it will cut down on time and effort.
the metal stick should be in the middle of the metal circle.
Old 03-20-2005, 01:41 PM   #16
bigd6983
lol metal stick thingy i love it.....but yea i never thought of that.....gotta give it a try next time im down there.......
Old 03-20-2005, 02:14 PM   #17
Crolero
thats got to be the best drawing on aleromod that ive ever seen. the best part is i know what your talking about.
Old 03-28-2005, 12:21 AM   #18
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
Originally posted by Crolero+Mar 20 2005, 06:35 AM--><div class='quotetop'>QUOTE(Crolero @ Mar 20 2005, 06:35 AM)</div><div class='quotemain'><!--QuoteBegin-|Rev|@Mar 20 2005, 01:27 AM
[/b][/quote]
Clearcoat paint will just flake off, the calipers get extremely hot. That's why you have to use special paint on them that can withstand high temperature. issed:
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 03-28-2005, 12:56 AM   #19
Deuce_Nukem
i'd do the newbish thing and go red to maek em look like baer brakes... plus i think red looks good on calpiers. . .
wow those do look really good though... when i ahve to change my brakes i may decided to clean and paint mine. . .
glad the dremel thing works. . . i like my dremel
Old 03-29-2005, 08:31 PM   #20
Monster189lb56
How would black look on calipers??
