03-21-2005, 04:54 PM
I took this out and tested it and its seems theres only 9V going to this. Can anyone confirm that?
I think I'm going to put 2 UV leds in there.
03-21-2005, 10:01 PM
I think there is a blueish film over the letter/numbers, so its gunna look funky maybe
03-21-2005, 11:32 PM
Kitteh is back!!!!
put a blue led in it, itll come up blue if thats what ur goin for, and its a 12v standard light (194 bulb) to be exact, i just put 4 led's there to cover the entire thing...
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
03-22-2005, 01:57 AM
Yea its a 194 but I have a battery tester and ran a 12V which came up poor and 9V test that came up good.
03-22-2005, 02:49 AM
It's a 12v source. I cut off the 194 socket head and spliced my intelliglow needles and light dancer into the source. Everything works fine.
Yeah, the overlay color will give off a blue light, but if you take out the gear select column and sandpaper all the black and coloring off, it's completely clear under there.
03-22-2005, 11:03 AM
i have 4-5 led's running off it. mine was similar, if you meter'ed it, it read about 9-10V. just throw the leds in with the resistors like normal, and it'll be fine.
03-22-2005, 08:21 PM
if you put 4 LEDs together in series (run them + to - and solder or twist them together) you won't need the resistor. or just use 3 and they'll be alot brighter.
03-23-2005, 01:01 AM
I had three about to go in but I tested the light again and there was no Volts or light coming from the cubby. Me thinks there is a fuse gone somewhere.
03-23-2005, 01:42 AM
um ur retarded. it depends on the LEDs.
03-23-2005, 07:38 AM
Originally posted by sound_xtreme+Mar 23 2005, 02:42 AM--><div class='quotetop'>QUOTE(sound_xtreme @ Mar 23 2005, 02:42 AM)</div><div class='quotemain'><!--QuoteBegin-turtles_ride@Mar 22 2005, 08:21 PM
if you put 4 LEDs together in series (run them + to - and solder or twist them together) you won't need the resistor.Â;-) or just use 3 and they'll be alot brighter.
[/b][/quote]
so's your mom. All the LEDs i've seen are 3V each (without the resistor) but don't listen to me, I'm retarded
03-23-2005, 12:48 PM
they come in all ranges of volts
03-23-2005, 04:03 PM
most colors are 2.3 -3 volts. i've seen some different ones. i sell a few wierd ones..
03-25-2005, 06:51 PM
I think I just had the Ebrake on....
