03-21-2005, 11:40 PM
Kitteh is back!!!!
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
03-21-2005, 11:43 PM
lol!! so uhhh...start the thread in 2 days!! Sheesh. j/k man.
03-21-2005, 11:50 PM
lookin forward to seein what you come up with. good luck :thumbsup:
03-22-2005, 12:07 AM
nice tease!
punk
03-22-2005, 10:48 AM
lemme know if you have any questions.
AnderbrA Innovations
Custom Automotive Lighting
www.anderbrainnovations.com
07 Cadillac STS V8
07 Mitsubishi Galant ES
00 Olds Alero - Parts
02 Lincoln LS V8 Sport - RIP
03-22-2005, 03:50 PM
I am also in process of a retrofit. I have E46 single xenon projectors and custom chrome bezels, Hella Gen 3 ballasts and D2S 4100K bulbs.
03-22-2005, 04:41 PM
OWN3D
this is what it will look like
07 Cadillac STS V8
03-22-2005, 05:33 PM
Originally posted by AnderbrA@Mar 22 2005, 03:41 PM
OWN3D
Except with more bumbers.. and headlight lenses... lol
If I did went to college...
03-22-2005, 11:30 PM
Kitteh is back!!!!
yea but it wont be a factory bumper
01 Suzuki gsxr 750
03-24-2005, 02:37 AM
Boost Guru
I'm also workin on a HID projector retrofit. quick question...would you need to modify it so that the low beams stay on with the high beams? it cant be a good thing for the HID bulb to flicker on and off if you're flashin the high beams a couple times.
03-24-2005, 09:30 AM
not sure that it does anythign for the bulbs, they are already warm by the time you would be flashing, so they ignite immediately.....
on another note....im sure you are the one that is going to get flashed....
07 Cadillac STS V8
03-25-2005, 02:11 AM
Boost Guru
maybe......its just that i've driven a few bmw's and mercedes at work and noticed when you flick on the high beams, the low beam HID's stay on while the high beams come on. i dunno if it'll do any harm, just figured it was designed that way for a reason. on a side note, the bi-xenon high beams on the mercedes are amazing  they light things up clearly from about 200 yards away. that would be the ideal route to take with the high beams.
i'll be ok...the projectors will be aimed correctly so it wont blind people, you'll just be able to see that gorgeous blue flicker from a distance.
03-25-2005, 01:42 PM
So who has what for sale and how much is it? LoL Is this a total new headlight to replace the factory one with? Mine are messed up that's what I need.
03-25-2005, 04:22 PM
im pretty sure that when you just pull the light stalk to flash the high beams, the low's stay on. its only when you push it so that they stay on, do the lows go off. ( r is it the other way? push pull....)
2001 Alero GLS - Sold!
03-26-2005, 12:59 AM
Kitteh is back!!!!
Well the wiring shouldnt be to confusing becasue id imagine the high beams have 3 wires coming into it..
Pos 12v
Neg
becasue of the daytime running lamps, pulling the power wire and trying to extent it to the lows would be hard and im not sure how the low voltage boost would effect it....ill figure something out.
01 Suzuki gsxr 750
03-26-2005, 01:30 AM
^ Theres a really easy way to disable the DRL's
03-26-2005, 08:50 AM
Kitteh is back!!!!
true...so that way ill just have to do this...Take the + from the brights that activate it, since everything works on a 12v systems and run it over to the regular headlight so theres a constant power flow. and incase that doesnt work then run the power from the reg headlight to a relay and the brights to the relay so itll cut off the power to the reg and the bright will hit the reg at the same time to turn both on at once....Its basic wiring actually
01 Suzuki gsxr 750
03-26-2005, 10:03 PM
Kitteh is back!!!!
got mine for $90 .MUAHAHAA
01 Suzuki gsxr 750
