12-29-2003, 08:00 PM
I just got a set of Halo Gauges for X-Mas. Love my wife. So anyway I get them all lined up which was a pain in mein arse. Hook them up using the Illumination wire out of my stereo harness and grounding to the stereo ground. I turn them on low and there is no sound but as I turn them up (brightness) I hear a high pitched buzzing sound. I was thinking maybe it was shorting out or I may need a fuse somewhere in there. Not sure what to do about it. I can't hear it with my stereo on, just enough to make me wonder if I should hook them up somewhere else.
12-29-2003, 08:53 PM
Isn't your illumination wire a variable voltage? That could be it, some electronics will make a noise if they operate at a different voltage than they're designed for.
12-29-2003, 10:11 PM
its normal. Mine buzz. its because of the different voltage
12-30-2003, 03:23 PM
Yeah its definately normal, mine does it too.
<a href=\'http://members.cardomain.com/r53silver91s2\' target=\'_blank\'>http://members.cardomain.com/r53silver91s2</a>
<img src=\'http://invision.aleromod.com/uploads/post-24-1088131656.gif\' border=\'0\' alt=\'user posted image\' />
12-30-2003, 04:04 PM
mine also...you get use to it...just turn your radio up
12-30-2003, 05:37 PM
The Founder
my gauges don't buzz.... just out of curiocity, where did you wire yours to and where did you ground it? Maybe if we get a consensus of where the wiring is, we can find a better way to wire them so they don't hum.
Mine are wired to the cubby light (i cut off the cubby light because I didn't like it, and I used the hole to put my Sirius radio controller wire through) and grounded to the big bolt behind the gauge cluster.
12-30-2003, 05:43 PM
I hooked mine up to the cubby hole light as well, but I didn't cut the wire so my cubby light still works. I can't remeber where I grounded it too. I guess I could check one of these days but I'm lazy so I probably willn't.
12-30-2003, 06:01 PM
Kitteh is back!!!!
nick where did you put your black box, thats whats making the humming noise, its becasue of the voltage supplied to it, mine do it to
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
12-30-2003, 06:19 PM
So I am thinking maybe I should get back in there and pull it out so I can hook it up to the cubby light? That stereo is a pain. Oh well, I had a shift knob that had neon on it as well it was pretty sweet..made that buzzing noise I really didn't think anything of it. Then it stopped working I think I shorted something out. I will probably get back in there and make a few wiring changes.
12-30-2003, 06:49 PM
The Founder
my black box is shoved in behind the hvac knobs...
12-30-2003, 11:06 PM
you might not br able to hear it, mines wired to the light both neg and hot wire. Box taped to a post in the dash between IC and middle vents
12-31-2003, 09:21 AM
wired to the gauge cluster power, can use both the stock dimmer and switch dimmer, and grounded it to a bolt behind the cluster, switch in that flip down pocket to the left
and yeah, it still buzzes very little, but still only realize it if i have no radio on and they're cranked up to bright
smirking is important
follow the titans
