Old 03-22-2005, 10:24 PM   #1
FormulaNERD
ok, so -alero- is too lazy to pull every fuse, and he checked the fuse for foglamps and horn, and they were fine... could any other fuse cause this?
also the blinkers dim when the fog switch is turned on, and the blinkers blink faster than normal.
Old 03-22-2005, 10:31 PM   #2
brim
brim's Avatar
holy crap batman
smirking is important
follow the titans
Old 03-22-2005, 11:25 PM   #3
The blinkers could be a bad flasher unit (if cars still have them )
Old 03-22-2005, 11:33 PM   #4
bigd6983
hm...you thought of checking the emergency light switch....seeing as you have checked everything else........this may produce some weird things......might just want to give it a check....
Old 03-23-2005, 12:55 AM   #5
FormulaNERD
bad ground near the driver strut tower.... thanks for your help everyone, a mod can close this.
