Old 03-24-2005, 02:45 PM   #1
PimpinGad
Hey guys I'm having some trouble finding the 894 in Sylvania Silverstars. I saw one post that Naich made that said the other numbers that are in the 800's will work. They make a silverstar fog light with the number 893 @ 37.5 watts, the other one is number 880 @ 27 watts. They both have the axial base and neither bend into a 90 degree angle. I would like to use the higher wattage bulb if possible, but I don't want to potentially burn up my wiring harness for the fogs. Help me!!!!!!!!
Old 03-24-2005, 04:08 PM   #2
Grouch
it'll work if it fits. I have 55-watt bulbs in mine, don't recall the part number. They've been in there over two years with no problem. The harness can handle 55's with ease, it's when you start going higher you'll get in trouble.
Old 03-24-2005, 04:35 PM   #3
j_smith
I have silverstar 880 bulbs in my fogs. I believe they are a little bit less wattage, but they still look much brighter than stock. They also match the silverstar low beams perfectly. They have a straight connector instead of a 90 degree one, but there is enough room that they install fine.
