Old 03-24-2005, 10:34 PM   #1
-Alero-
-Alero-'s Avatar
Unhappy
i recently bought a FFP pulley from Formulanerd, and i would like to know how to install it, anyone have good detailed instructions of who has actually installed it?
AUTOBOT
Old 03-24-2005, 11:01 PM   #2
I know you gotta take off the pass side wheel and the fender liner, but I don't know how it bolts to the motor and what to use to release the tention in the belt
Old 03-24-2005, 11:03 PM   #3
-Alero-
-Alero-'s Avatar
well i also have to install a new belt, and i have it, and i dont know how to install the belt
AUTOBOT
Old 03-24-2005, 11:26 PM   #4
mfuller
You will have to dettach the passenger-side motor mount (right by the cruise control module). Be sure to support the engine via a jack and a wood block - you can support the oil pan; just don't lift the motor by it!
Old 03-24-2005, 11:32 PM   #5
-Alero-
-Alero-'s Avatar
damn..... can i have some sort of place install this pulley and belt? like pep boys, or would it have to be under a stealership?
AUTOBOT
Old 03-24-2005, 11:42 PM   #6
mfuller
A couple of problems:
The 24X reference ring that is pressed into your factory harmonic balancer must be removed and transferred to the new FFP pulley. It takes patience to not magle the ring during the removal process (it doesn't come out easy).
Also, it's very easy to damage the front crankshaft seal when replacing the crank pulley - I had to replace mine (actually, a dealer did), as I started to drip a little oil after a few weeks. A job best handled by a mechanic.
Find someone you trust to do the job right......you probably won't find them at Pep Boys.
Old 03-24-2005, 11:45 PM   #7
-Alero-
-Alero-'s Avatar
should i print out some instructions or something for a mech? so he knows how to do it right? or maybe some pictures, also how much do you think it'd be to pay to have it installed
AUTOBOT
Old 03-25-2005, 12:10 AM   #8
-Alero-
-Alero-'s Avatar
also how long is the new belt supposed to be? and the pulley comes with nothing but itself right? just the pulley and nothing else?
AUTOBOT
Old 03-25-2005, 09:04 AM   #9
mfuller
It's probably not a bad isea to make them aware of the 24X reference ring. Also, if you're going to have a mech. do the job for you, cough up the extra dough to replace the front seal - it's cheap insurance. Other than that, they shouldn't need any instructions, although the pulley does come with some directions, and a full install is detailled on www.fastfwdperformance.com. You must supply a new belt; I think I used one 85.5" long.
Old 03-26-2005, 03:31 PM   #10
-Alero-
-Alero-'s Avatar
and what is this front seal look like? and how much is it?
AUTOBOT
