03-27-2005, 11:48 PM
ok, when ever i lock my car using the keyfob, the car used to honk once. and now when i lock the car it doesnt honk but it still locks.... anybody know how to get it a honkin again?
AUTOBOT
03-28-2005, 12:48 AM
where my knickers at?
Nope, but when I push the lock button on my door, there used to be a 'ding ding ding' and then 20 seconds after the doors were closed the horn would honk and the doors would lock...... now there's no dings but the horn still honks and the doors still lock... I liked having the reminder dings.
--UPDATE-- $88,000 in debt.
03-28-2005, 01:03 AM
i know there is a process you can do just like, when you reset the Change Oil light
AUTOBOT
03-28-2005, 01:16 AM
Programmable Horn Chirp
from page 2-13 of Owner's Manual
When you use the remote keyless entry transmitter to lock the doors or use the delayed locking feature the parking lamps will flash and the horn will chirp.
The programmable horn chirp can be disabled by pressing and holding either of the door lock switches in the unlock position for 10-seconds with the ignition key ON and all of the doors closed. When you hear the horn chirp, programming is complete.
To reactivate the horn chirp feature, repeat the above procedure.
03-28-2005, 01:19 AM
smlz, do you have an aftermarket radio? If so, you loose some of your warning chimes unless you incorporate the factory radio back into the system somewhere. I think there is a harness or device you can get to bypass having to actually put the stock radio in somewhere, but it's too late and I can't think of it at the moment.
Might look at the Programming Power Door Locks FAQ to see if that will fix it.
03-28-2005, 01:23 AM
Nope, I did have an amp installed for use with my Inf speakers tho............................................... .................................................. .................................................. ...................... did the peeps ferk up my 'chirps'??
04-02-2005, 02:15 PM
my chirp when i hit the lock when the doors still open, still works and i got a pioneer deck installed and no factory stereo relocated
04-02-2005, 03:49 PM
AutoCross Alero
mine used to be when i pushed the lock button once the doors locked, when i pushed it a second time the horn chirped(honked(whatever)) now i have viper so it doesnt matter.
04-03-2005, 02:08 PM
My '01 use to do this honk after locking up the car. I turned it off just to try it out and when i went back to set it back to the honk, it won't do it. I even went thru the manual a few times--same result.
04-06-2005, 12:03 PM
[boosted 2.4L]
same here, used to work, now no luck. i need help re-enabling it. i tried the 10 second thing. any other guesses?
