Old 12-30-2003, 08:11 PM   #1
vagnozzi
When I bought my Alero, it lacked a passenger foglight. I bought a used one with mounting bracket off eBay for 35 bucks. Anyone know anything in particular about installing it I should know? Seems like a simple bolt in, but where is the power located that it willl be plugged into? Thanks
Chris
Old 12-30-2003, 10:34 PM   #2
alerosport.com
if you said it was only missing one then... there was factory fogs there already, right? If so then the plug in will be just laying down there... you may wan t to make sure it is not coroded and make sure it gets a good connection. but it should be laying down there where it would reach the fog when mounted.
Good luck
Old 12-31-2003, 08:55 AM   #3
When installing, Remove the headlight to get better access and undo the panel under the foglight area too, in case you gotta go under the car.
If you waht to raise the car up, use ramps or jack stands!!!
Old 12-31-2003, 01:03 PM   #4
vagnozzi
How do exactly access the foglight? Do I go underneath and remove a screw or something, or do I take out the headlight? If the headlight, how is that done? Thanks
Chris
Old 12-31-2003, 01:49 PM   #5
misslindseysue
You have to take off the plastic guard that's under it, it's only a couple screws. Or to get to it from the top, take the headlight out through the engine bay.
Old 12-31-2003, 03:33 PM   #6
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
I just took out the headlight when Ihad to replace a bulb
just lift up on the black pins,and pull it out(after disconnecting wiring)
ImSoBored is offline   Reply With Quote
