Old 01-02-2004, 03:48 AM   #1
j{}n
j{}n's Avatar
j{}n is an unknown quantity at this point
Send a message via AIM to j{}n Send a message via MSN to j{}n
Arrow
as of late i've had a problem with what i believe to be my transmission. i'll hit the gas and nothing really happens, then after a bit my "trac off" light turns on. it will stay like this until i shut my car off. is this the transmission? if so, will one of those devices that firm up your shifts remedy this? thank you in advance
'05 mazda 3
zoom zoom biatch
j{}n is offline   Reply With Quote
Old 01-02-2004, 04:17 AM   #2
Final-Reality
I have the transmission slipping problem, and it does seem to be worse in the winter, as it never happened through the summer but it's doing it more often now, just like it was last winter...
Anyways, my trac light never once came on as a result of this, so it may be different?
Old 01-02-2004, 06:27 AM   #3
AmericasChoice
how many miles do u have on the car?
Old 01-02-2004, 04:11 PM   #4
overdrive75
If you transmission was slipping you would be setting a code for slipping transmission it would be I am not sure what the code number is, but I do know that It will set a check engine code.
