Old 04-06-2005, 01:44 PM   #1
amh
Hi
I was just replacing a new fuse to the horn (it was allready broken when i bought my Alero).
So i install the new one and horn starts working, i mean i start blowing (like a hell) immediatly the fuse touch its connectors.
Didnt search the problem yet so far.
Trying to search help from the forums searh, but found only one topic. There someone has replaced the steeringwheel airbag system for the same reason.
Question is where to start searching this noisy problem.
My Alero is 2000 2.4 4dr
amh
Old 04-06-2005, 06:24 PM   #2
brsexton
I had that exact same issue with my 2003 when I had only 10k. The horn would get stuck and start blowing on its own. They replaced my drivers side airbag because the horn switch inside the airbag cover. Yours may be something else though.
2005 Honda CR-V AWD
Old 04-09-2005, 10:29 AM   #3
amh
Problem has been solved. It was broken hornrelay.
Thanks for support :grin:
amh
