Old 04-06-2005, 10:34 PM   #1
cannaert
cannaert's Avatar
cannaert is an unknown quantity at this point
Send a message via AIM to cannaert
my highs lined up but my lows are not...
any one have this prob or now what i can do to fix it.
1st pic is lowes and 2nd is highs
[attachmentid=5894]
[attachmentid=5895]
if pics dont work go here http://www.cardomain.com/id/cannaert
DONT BUY A JEEP.
It will take over your Life.
cannaert is offline   Reply With Quote
Old 04-06-2005, 10:37 PM   #2
Vtolds
H&B Shipping Agent
Vtolds's Avatar
It shows how to adjust them in your owners manual. Basically there are 2 reverse torx bolts, I think they call them. and you adjust them, buy using I guess you could call them levels inside the headlight.
Old 04-06-2005, 10:39 PM   #3
turtles_ride
where do u buy the reverse torx and what size is it?
Old 04-06-2005, 10:49 PM   #4
cannaert
cannaert's Avatar
I did that. But for some reason the low is still to high. If you line up the lowes the hight goes even higher.
I getting really piss at.
DONT BUY A JEEP.
Old 04-06-2005, 10:54 PM   #5
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Drive it to Vermont I'll fix them for you :P When I did mine I just used a regular socket, but it kinda chewed up the bolt.
Old 04-06-2005, 10:59 PM   #6
alerosport.com
most auto stores turtle.
my car does the just about the same thing i had my lows set just right, but it put my highs, up in the trees... which was worthless. so i focused them lower and the highs work out perfect but the lows are hetting the pavement alot lower and reducing vision not alot but less...
Old 04-06-2005, 11:08 PM   #7
cannaert
cannaert's Avatar
I think i might take the hole thing apart and find out what the h@&# is wrong with it. I dont know i shought just go buy a new light from the Junk yard.
DONT BUY A JEEP.
Old 04-06-2005, 11:13 PM   #8
Vtolds
H&B Shipping Agent
Vtolds's Avatar
as long as your getting, everything lined up right they should be fine, you are also suppost to have someone sitting in the drivers seat so they arent off like that, but I didnt and mine turned out fine.
Old 04-07-2005, 05:04 PM   #9
-Alero-
-Alero-'s Avatar
i just used some pliers and basically said F*ck it
AUTOBOT
Old 04-08-2005, 08:59 AM   #10
turtles_ride
maybe if you cleared your corners, when you put the lights back together they weren't pressed together evenly and so the beams project differently?
Old 04-08-2005, 02:22 PM   #11
flalero
I always thought that the passenger side light was supposed to be aimed a little higher than the driver side? If you aim the driver side to the same height as the passenger, you will blind people.
Old 04-08-2005, 02:52 PM   #12
Crolero
thats what i thought, that the headlights always shined more on the passenger side.
Old 04-09-2005, 12:15 AM   #13
cannaert
cannaert's Avatar
See I havent yet torn the coners out. It was like that when i bought it. I have been messing with it since day one.
DONT BUY A JEEP.
