Old 04-07-2005, 01:41 AM   #1
tonkatoyx2
Hey guys, my left blub on my left break light is out. ne of you guys no what light i need and how to but the blub in there???
i unscrewed the 2 screws where the 3rd break light was and i wiggled it and it was still up there really tight. how do i take this thing downto put the lgiht in
Thanks alot!
Old 04-07-2005, 01:42 AM   #2
tonkatoyx2
i meant 2 say one ofmy 3 bulbs on my 3rd break light is out
Old 04-07-2005, 08:50 AM   #3
Str8tFKNuUP
Str8tFKNuUP is an unknown quantity at this point
Mine all blew at once back in january, basically after you unscrew it it should just pop out, are you sure there isn't 3 screws? if I can remember correctly there was one on each side and one in the middle, but I could be wrong, I just remember it not being hard at all to replace.
As for which light you need, just go to your local parts store and tell them make and model and they'll bring it up on their computer for ya.
<img src=\'http://xxdownloadsxx.2myip.com/strtfknuup/My%20Pictures/7aad03196d79d2a461fa8235fe34dd8d.gif\' border=\'0\' alt=\'user posted image\' />
Str8tFKNuUP is offline   Reply With Quote
Old 04-07-2005, 10:49 AM   #4
Cyber Knight
Swank
Cyber Knight's Avatar
After you take the two nuts off there is a tab on each end of the housing that you need to press inward (you only need to push one) then pull the assembly out. Now you can unclip the red reflective piece (don't break the clips) and you'll be able to get at the 3 bulbs from the front, but they're in there pretty tight, so you might want to unscrew the 3 torx screws from the back of the plastic piece that holds the 3 bulbs in to get at them easier. Much easier than it sounds. I can post 'how to' pics tonight if needed. The bulb number for those is 921.
Old 04-07-2005, 05:31 PM   #5
tonkatoyx2
Thanks alot guys, i got it fixed but i broke one my clips tho LOL
well thanks again.
chow
Old 04-07-2005, 05:33 PM   #6
I guess you didn't read very well...he said "be careful not to break the clips" sheesh
