Old 01-03-2004, 04:48 AM   #1
myowneq
myowneq is an unknown quantity at this point
I have an issue that is confusing me. My car has developed a noise in the front driver side. It isn't always there and seems to happen most when I am braking to a stop, but not exclusively so. I pulled the front brake pads and they still have a bit on them. (45k miles on stock pads). There doesn't look to be any unhealthy marks on the rotors.
I have only one guess as to what might have happened. About three weeks ago, I hit a curb doing about 20mph and damaged my driver side rim. The noise started approximately 10 days later.
Does this sound like maybe a bearing was busted? Or is there something else that might make this noise?
This one is easy. If the AC / Heater is turned off completely, should the car still be passing air from outside through the vents when the car is in motion?
myowneq is offline   Reply With Quote
Old 01-03-2004, 08:29 AM   #2
When the ac/heat is off outside will pass thru the vents. This is normal. Take notice to the green light on the picture of the cars on the buttons below the ac fan speed knob. You only get outside air when using the defroster.
What does the noise sound like? Does the car pull or have trouble keeping speed since this happened? If it does, it's a control arm.
Try to descirbe the noise, I may be able to give a better answer
Old 01-03-2004, 09:55 AM   #3
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
it probbaly just a bent rim, my friends van had a bent rim and it vibrated and made noise
ImSoBored is offline   Reply With Quote
Old 01-03-2004, 10:15 AM   #4
3.4Alero
Yes, all cars have air entering the cabin even when the fan is off.
I agree, please describe the noise. Is it a squealing, grinding, rumbling, etc.?
Old 01-03-2004, 11:34 AM   #5
johny_boy32
johny_boy32's Avatar
its prolly like ImSoBored said...its prolly the vibration from the wheel
Old 01-03-2004, 03:13 PM   #6
Oldsmopimp
Yea, sometimes my front drivers side brakes make a "crunching" type noise when stopping. Usually if Im at a light, or a drive thru and just slowly creeping up. I did a lil research before and noticed Olds had problems with faulty rotors and such. My car stopps fine...so ive just kinda let that problem go. It dosent seem to critical.
But maybe that is the noise you are hearing too?
Old 01-04-2004, 12:44 AM   #7
myowneq
The sound is like an old rusty wheel. It squeaks when I am moving. Not all the time though. There no vibrations, clunky noises, grabbing, pulling, etc. Just the squeak. It is really annoying since my car is not even two years old yet. I thought it might have been the brakes also, but the pads are fine and there is no unhealthy wear on the rotors.
Any ideas?
Old 01-04-2004, 12:46 AM   #8
OLDSskool
If you hear a crunching when comin to a stop it means your caliper is bunnyed.. i have had my calipers rebuilt 3 times now... its a known issue to GM dealerships.. have them check it out if yo uare under warranty
